Проблема с изменением записи
Всем добрый день. Проблема с изменением записи. Пишу следующее: String Author,Name,City,Printer,YearPrint,CountPage,ISBN,Comment,IdType; Author = Authortbx2.Text; Name = Nametbx2.Text; City = Citytbx2.Text; Printer = Printertbx2.Text; YearPrint = Yeartbx2.Text; CountPage = CountPagetbx2.Text; ISBN = ISBNtbx2.Text; Comment = Commenttbx2.Text; IdType = TypeLitddl2.SelectedValue; String Filter = "IdLiterature = "+IdLit; SqlDataAdapter sqladaptSR = new SqlDataAdapter ("SELECT * FROM tSuggestedReading WHERE IdLiterature="+IdLit,sqlCommonConnect); sqladaptSR.SelectCommand.CommandText ="SELECT * FROM tSuggestedReading WHERE IdLiterature="+IdLit; DataSet dsSR = new DataSet (); SqlCommandBuilder cmdSR = new SqlCommandBuilder (sqladaptSR); sqladaptSR.Fill (dsSR,"tSuggestedReading"); DataColumn [] keys = new DataColumn [1]; keys[0] = dsSR.Tables["tSuggestedReading"].Columns["IdLiterature"]; dsSR.Tables["tSuggestedReading"].PrimaryKey = keys; dsSR.Tables["tSuggestedReading"].Rows[0]["Author"] = Author; sqladaptSR.Update (dsSR.Tables["tSuggestedReading"]); Выдает следующую ошибку: Exception Details: System.InvalidOperationException: Dynamic SQL generation for the UpdateCommand is not supported against a SelectCommand that does not return any key column information. ... |
| 27.03.2006, 12:06:49 |
start [/forum/search_topic.php?author=plankton777&author_mode=last_posts&do_search=1]: |
203ms |
27ms |
| others: | 719ms |
| total: | 1014ms |
