как подключить vsFlexGrid или TDBGrid к ado.net?
код такой: ss = "SELECT a.[ID],b.name,a.[vvod],a.[wiring],a.[amount] FROM [jur_coming] a left join syllables b on a.[syllables_id]=b.ID" Dim selectCMD As SqlCommand = New SqlCommand(ss, cn) Dim DA As SqlDataAdapter = New SqlDataAdapter DA.SelectCommand = selectCMD Dim DS As DataSet = New DataSet DA.Fill(DS, "prih") vsFlexGrid .DataSource = DS - ошибка в этой строке Unable to cast object of type 'System.Data.DataSet' to type 'TrueDBGrid80.ICursor'. ... |
| 17.05.2006, 08:28:33 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1353328]: |
35ms |
| others: | 196ms |
| total: | 285ms |
