Где ошибка?
Коллеги, помогите разобраться, Нужно заполнить даталист, ошибок синтаксических в коде нет, запускается, но при заходе выдает ошибку. Вод код где происходит ошибка, а сама ошибка ниже. ---------------------------------- Private Sub Page_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load 'Put user code to initialize the page here adptNTConfig = Cache("adptNTConfig") dsNTConfig = Cache("dsNTConfig") ' Run the first time page is displayed. If Not IsPostBack Then ' For each row in the table... Dim rowNext As DsNTConfig.NT_ConfigRow For Each rowNext In dsNTConfig.NT_Config ' Create a new list item. Dim lstNew As New ListItem lstNew.Text = rowNext.NTID & " with Run Number: " & rowNext.NT_run_nbr lstNew.Value = rowNext.NTID ' Add the list item to the drop-down list. drpRunNbr.Items.Add(lstNew) Next ' Select the first item in the list. drpRunNbr.SelectedIndex = 0 End If ------------------------------------------ А вот что гоорит браузер: Server Error in '/Baikal_v1' Application. -------------------------------------------------------------------------------- Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.NullReferenceException: Object reference not set to an instance of an object. Source Error: Line 56: ' For each row in the table... Line 57: Dim rowNext As DsNTConfig.NT_ConfigRow Line 58: For Each rowNext In dsNTConfig.NT_Config Line 59: ' Create a new list item. Line 60: Dim lstNew As New ListItem Source File: c:\inetpub\wwwroot\Baikal_v1\Nt_config.aspx.vb Line: 58 Stack Trace: [NullReferenceException: Object reference not set to an instance of an object.] Baikal_v1.Nt_config.Page_Load(Object sender, EventArgs e) in c:\inetpub\wwwroot\Baikal_v1\Nt_config.aspx.vb:58 System.Web.UI.Control.OnLoad(EventArgs e) System.Web.UI.Control.LoadRecursive() System.Web.UI.Page.ProcessRequestMain() --------------------------------------------------------------- ... |
| 26.05.2006, 00:07:59 |
Где ошибка?
Ну, судя по коду, Код: plaintext дает значение dsNTConfig null. После этого попытка обращения к его проперте: Код: plaintext и выдает ошибку. Проверь, есть ли в кэше нужный объект, правильно ли он оттуда вычитывается. Сергей ------------------ Умом Россию не понять... С умом она несовместима. ... |
| 26.05.2006, 11:32:56 |
Где ошибка?
gerssНу, судя по коду, Код: plaintext дает значение dsNTConfig null. После этого попытка обращения к его проперте: Код: plaintext и выдает ошибку. Проверь, есть ли в кэше нужный объект, правильно ли он оттуда вычитывается. Сергей ------------------ Умом Россию не понять... С умом она несовместима. Я не силен в программированиие, код я его писал по книжке, т.е. изменил название таблички и полей. Как можно правильно заполнить dsNTConfig = Cache("dsNTConfig") если есть табличка, которая называется NT_Config, Коннект: SQLConnection1 Адаптер: SQLAdapter1 Datasource: DsNTConfig ... |
| 26.05.2006, 12:48:08 |
Где ошибка?
Просто ты берешь dsNTConfig из кэша. А есть ли он там? Где, как, кто его туда кладет? Может ты что-то не дописал из примера? Сергей ------------------ Умом Россию не понять... С умом она несовместима. ... |
| 26.05.2006, 15:00:33 |
Где ошибка?
gerssПросто ты берешь dsNTConfig из кэша. А есть ли он там? Где, как, кто его туда кладет? Может ты что-то не дописал из примера? Сергей ------------------ Умом Россию не понять... С умом она несовместима. Сергей, исходя из моей структуры (которую я выше привел), как заполнить кэш dsNTConfig? ... |
| 26.05.2006, 17:57:32 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1353310]: |
204ms |
51ms |
| others: | 197ms |
| total: | 497ms |
