C#, ADO.net & OrderDetailsDataTable_ColumnChanging
Как добавить обработчик ColumnChanging for DataTable? (vs2005, C#) In msdn wrote : To create the validation event handlers Open the NorthwindDataSet in the Dataset Designer by double-clicking the NorthwindDataSet.xsd file in Solution Explorer. Double-click the Quantity column in the OrderDetails table to create the OrderDetailsDataTable_ColumnChanging event handler. (In C# only the data table's partial class will be created.) Note Double-clicking the table name (Order Details in the title bar) creates an event handler for the RowChanging event. Я сделал всё как написано!!!! In result I have this code : namespace ValidationWalkthrough { partial class NorthWindDataSet { partial class OrderDetailsDataTable { } } } But don't have event handler How to add event handler? C ув. Tors ... |
| 30.07.2006, 18:24:12 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1353227]: |
153ms |
| others: | 180ms |
| total: | 383ms |
