Такая проблемка неработает Update
Такая проблемка неработает Update.Вот пример кода ,помогите плизззззз,BD na Accsess Зарание спасибо!!! private void up_btn_Click(object sender, System.EventArgs e) { try { this.oleDbDataAdapter1.UpdateCommand.CommandText = "UPDATE BookDb SET "+ "author ='"+ this.author_textBox.Text +"', EditionNumber ='"+this.ed_textBox.Text + "', ISBN ="+this.isbn_textBox.Text+", Title ='"+ this.title_textBox.Text+"'" + " WHERE ISBN ="+ this.isbn_textBox.Text; //open the bridge between the application and the datasource this.oleDbConnection1.Open(); this.oleDbDataAdapter1.UpdateCommand.Connection = oleDbConnection1; //execute the qurey this.oleDbDataAdapter1.UpdateCommand.ExecuteNonQuery(); //close the connection this.oleDbConnection1.Close(); MessageBox.Show("Record updated Successfully"); //inform the user //clear the form this.title_textBox.Text = ""; this.isbn_textBox.Text = ""; this.author_textBox.Text = ""; this.ed_textBox.Text = ""; //show the qurey this.qurey_label.Text = ""; this.qurey_label.Text = oleDbDataAdapter1.UpdateCommand.CommandText.ToString(); } catch(System.Data.OleDb.OleDbException exp) { //close the connection this.oleDbConnection1.Close(); MessageBox.Show(exp.ToString()); } } ... |
| 30.01.2007, 20:13 |
SharkiТакая проблемка неработает Update.Вот пример кода ,помогите плизззззз,BD na Accsess Зарание спасибо!!! private void up_btn_Click(object sender, System.EventArgs e) { try { this.oleDbDataAdapter1.UpdateCommand.CommandText = "UPDATE BookDb SET "+ "author ='"+ this.author_textBox.Text +"', EditionNumber ='"+this.ed_textBox.Text + "', ISBN ="+this.isbn_textBox.Text+", Title ='"+ this.title_textBox.Text+"'" + " WHERE ISBN ="+ this.isbn_textBox.Text; //open the bridge between the application and the datasource this.oleDbConnection1.Open(); this.oleDbDataAdapter1.UpdateCommand.Connection = oleDbConnection1; //execute the qurey this.oleDbDataAdapter1.UpdateCommand.ExecuteNonQuery(); //close the connection this.oleDbConnection1.Close(); MessageBox.Show("Record updated Successfully"); //inform the user //clear the form this.title_textBox.Text = ""; this.isbn_textBox.Text = ""; this.author_textBox.Text = ""; this.ed_textBox.Text = ""; //show the qurey this.qurey_label.Text = ""; this.qurey_label.Text = oleDbDataAdapter1.UpdateCommand.CommandText.ToString(); } catch(System.Data.OleDb.OleDbException exp) { //close the connection this.oleDbConnection1.Close(); MessageBox.Show(exp.ToString()); } } просто не выполняет сохранение или выбрасывет хоть какое-то исключение? ... |
| 31.01.2007, 16:58 |
Я извеняюсь что пропал,и вобще я извеняюсь что я такая свинья,но вот програмка которую я написал может у кого нибудь будет желание и время посмотреть и сказать где мои ошибки.Зарание спасибо,буду очень благодарен!!! ... |
| 01.02.2007, 19:31 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1352966]: |
52ms |
29ms |
| others: | 207ms |
| total: | 326ms |
