Не работает SQL скрипт...
Есть скрипт создания БД: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. при создании SqlCommand, а потом ExecuteNonQuery() пишет такое: "Incorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near the keyword 'SET'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax near 'GO'.\r\nIncorrect syntax ... ... |
| 13.03.2007, 03:59 |
GO - нет такой инструкции.... ПАрсить через GO и запускать кусками. авторGO is not a Transact-SQL statement; it is a command recognized by the osql and isql utilities and SQL Query Analyzer. ... |
| 13.03.2007, 09:41 |
можно запустить sqlcmd -i scrpt.sql в вашей программе ... |
| 13.03.2007, 10:37 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1352909]: |
84ms |
58ms |
| others: | 240ms |
| total: | 444ms |
