Parameters
Добрый день! Не подскажите как можно использовать 2 параметра для нескольких запросов? К примеру у меня есть 2 запроса: Dim commMMS1 As OracleCommand = New OracleCommand("select count(t.dialed) as COUNT_OUT, sum(t.duration) as SUMMA_D_OUT from calls_all t where t.lcal_lcal_id = 39 and t.start_time>=:PARAM1 and t.start_time<=to_date(:PARAM2)+1", conn) commMMS1.CommandType = CommandType.Text Dim commMMS2 As OracleCommand = New OracleCommand("select count(t.dialed) as COUNT_IN, sum(t.duration) as SUMMA_D_IN from calls_all t where t.lcal_lcal_id = 38 and t.start_time>=:PARAM1 and t.start_time<=to_date(:PARAM2)+1", conn) commMMS2.CommandType = CommandType.Text Помогите пожалуйста, очень нужно. ... |
| 22.06.2007, 13:51 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1352735]: |
38ms |
35ms |
| others: | 205ms |
| total: | 315ms |
