подскажите плиз dataset
Public Class Form1 Private userdata As New DataSet Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click Dim connectionstring As String connectionstring = _ "data source=172.16.1.5;initial catalog=bvista;user id=sa;" Using testconnection As SqlConnection = New SqlConnection(connectionstring) Dim testcommand As SqlCommand = testconnection.CreateCommand() testcommand.CommandText = "select posc from address;" & "select posc, kod from users" Dim dataadapter As New SqlDataAdapter(testcommand) dataadapter.Fill(userdata) End Using End Sub Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click DataGridView1.DataSource = userdata End Sub End Class ... |
| 09.02.2008, 23:37 |
gulyaev.sPublic Class Form1 Private userdata As New DataSet Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click Dim connectionstring As String connectionstring = _ "data source=172.16.1.5;initial catalog=bvista;user id=sa;" Using testconnection As SqlConnection = New SqlConnection(connectionstring) Dim testcommand As SqlCommand = testconnection.CreateCommand() testcommand.CommandText = "select posc from address;" & "select posc, kod from users" Dim dataadapter As New SqlDataAdapter(testcommand) dataadapter.Fill(userdata) End Using End Sub Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click DataGridView1.DataSource = userdata End Sub End Class почему то не заполняет данные , скажите где ошибка , ведь должна заполнять ... ... |
| 09.02.2008, 23:38 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1352393]: |
45ms |
32ms |
| others: | 241ms |
| total: | 359ms |
