Нет коннекта к oracle
Здравствуйте. Буквально неделю назад получила задание написать простейший Web сервис на c# подключение к БД Oracle и выборка данных из таблиц. Использую OracleClient, string ConnectionString = "Data Source=SUB1,Persist Security Info=True;Password=190;User ID=190"; OracleConnection MainOraConnection = new OracleConnection(ConnectionString); MainOraConnection.Open(); OracleDataAdapter myOraData = new OracleDataAdapter(" SELECT * FROM PRODUCT", MainOraConnection); myOraData.SelectCommand.CommandType = CommandType.Text; DataSet ds2 = new DataSet(); myOraData.Fill(ds2); return ds2; сервис отрабатывет , но выдает след System.Data.OracleClient.OracleException: ORA-12170: TNS:Connect timeout occurred в System.Data.OracleClient.OracleException.Check(OciErrorHandle errorHandle, Int32 rc) в System.Data.OracleClient.OracleInternalConnection.OpenOnLocalTransaction(String userName, String password, String serverName, Boolean integratedSecurity, Boolean unicode, Boolean omitOracleConnectionName) в System.Data.OracleClient.OracleInternalConnection..ctor(OracleConnectionString connectionOptions) в System.Data.OracleClient.OracleConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject) в System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnection owningConnection, DbConnectionPool pool, DbConnectionOptions options) в System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject) в System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject) в System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection owningObject) в System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) в System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) в System.Data.OracleClient.OracleConnection.Open() в Service.GetMenOracle() в c:\Users\elena\Documents\Visual Studio 2008\WebSites\WebSite3\App_Code\Service.cs:строка 55 в TOAD коннект проходит нормально, и приложение работает , а в сервисе нет. Я понимаю , что вопрос простой, но у самой не получается решить :-(. Если что дайте ссылочку где почитать. ... |
| 27.05.2008, 15:23 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1352265]: |
56ms |
40ms |
| others: | 216ms |
| total: | 356ms |
