Скажите что делаю не правильно?
Скажите что делаю не правильно? Просто все зависает и все не чего не происходит, мож есть способ просто скопировать один DataTable в нужный code Me.Pony_vgeneralwaybillTableAdapter.Fill(Me.PonyDataSet.pony_vgeneralwaybill) Me.VGeneralWaybillTableAdapter.Fill(Me.Main1DataSet.vGeneralWaybill) Dim WaybillNumber As String Dim WaybillDate As String Dim ORG As String Dim DEST As String Dim S_Code As String Dim S_Name As String Dim S_CompanyTitle As String Dim S_City As String Dim S_Country As String Dim S_Address As String Dim C_Name As String Dim C_CompanyTitle As String Dim C_City As String Dim C_Country As String Dim C_Address As String Dim ShipmentDescription As String Dim Items As Integer Dim Weight As Single Dim Payer As Integer Dim ServiceCode As String Dim DeliveryDT As String Dim Consignee As String Dim i As Integer Dim j As Integer For i = 0 To Me.Main1DataSet.vGeneralWaybill.Rows.Count WaybillNumber = Me.Main1DataSet.vGeneralWaybill.Rows(i)("WaybillNumber") WaybillDate = Me.Main1DataSet.vGeneralWaybill.Rows(i)("WaybillDate") ORG = Me.Main1DataSet.vGeneralWaybill.Rows(i)("ORG") DEST = Convert.ToString(Me.Main1DataSet.vGeneralWaybill.Rows(i)("DEST")) S_Code = Convert.ToString(Me.Main1DataSet.vGeneralWaybill.Rows(i)("S_Code")) S_Name = Convert.ToString(Me.Main1DataSet.vGeneralWaybill.Rows(i)("S_Name")) S_CompanyTitle = Convert.ToString(Me.Main1DataSet.vGeneralWaybill.Rows(i)("S_CompanyTitle")) S_City = Me.Main1DataSet.vGeneralWaybill.Rows(i)("S_City") S_Country = Me.Main1DataSet.vGeneralWaybill.Rows(i)("S_Country") S_Address = Me.Main1DataSet.vGeneralWaybill.Rows(i)("S_Address") C_Name = Convert.ToString(Me.Main1DataSet.vGeneralWaybill.Rows(i)("C_Name")) C_CompanyTitle = Convert.ToString(Me.Main1DataSet.vGeneralWaybill.Rows(i)("C_CompanyTitle")) C_City = Me.Main1DataSet.vGeneralWaybill.Rows(i)("C_City") C_Country = Me.Main1DataSet.vGeneralWaybill.Rows(i)("C_Country") C_Address = Me.Main1DataSet.vGeneralWaybill.Rows(i)("C_Address") ShipmentDescription = Convert.ToString(Me.Main1DataSet.vGeneralWaybill.Rows(i)("ShipmentDescription")) Items = Me.Main1DataSet.vGeneralWaybill.Rows(i)("Items") If Me.Main1DataSet.vGeneralWaybill.Rows(i)("Weight") Is DBNull.Value Then Weight = 0 Else Weight = Convert.ToSingle(Me.Main1DataSet.vGeneralWaybill.Rows(i)("Weight")) End If Payer = Me.Main1DataSet.vGeneralWaybill.Rows(i)("Payer") ServiceCode = Me.Main1DataSet.vGeneralWaybill.Rows(i)("ServiceCode") DeliveryDT = Me.Main1DataSet.vGeneralWaybill.Rows(i)("DeliveryDT") Consignee = Me.Main1DataSet.vGeneralWaybill.Rows(i)("Consignee") For j = 0 To (Me.PonyDataSet.pony_vgeneralwaybill.Rows.Count - 1) If WaybillNumber = Me.PonyDataSet.pony_vgeneralwaybill.Rows(j)("WaybillNumber") Then ins = False End If If ins = False Then If Me.PonyDataSet.pony_vgeneralwaybill.Rows(j)("Consignee") = "" Then up = True End If End If Next If ins = True Then Dim row As DataRow = Me.PonyDataSet.pony_vgeneralwaybill.NewRow() row("WaybillNumber") = WaybillNumber row("WaybillDate") = WaybillDate row("ORG") = ORG row("DEST") = DEST row("S_Code") = S_Code row("S_Name") = S_Name row("S_CompanyTitle") = S_CompanyTitle row("S_City") = S_City row("S_Country") = S_Country row("S_Address") = S_Address row("C_Name") = C_Name row("C_CompanyTitle") = C_CompanyTitle row("C_City") = C_City row("C_Country") = C_Country row("C_Address") = C_Address row("ShipmentDescription") = ShipmentDescription row("Items") = Items row("Weight") = Weight row("Payer") = Payer row("ServiceCode") = ServiceCode row("DeliveryDT") = DeliveryDT row("Consignee") = Consignee Me.PonyDataSet.pony_vgeneralwaybill.Rows.Add(row) ins = False End If If ins = False And up = True Then Dim filter As String = "WaybillNumber='" & WaybillNumber.ToString() & "'" Dim upRows As DataRow() = Me.PonyDataSet.pony_vgeneralwaybill.Select(filter) upRows(0).BeginEdit() upRows(0)("DeliveryDT") = DeliveryDT upRows(0)("Consignee") = Consignee upRows(0).EndEdit() up = False End If Next Me.Pony_vgeneralwaybillTableAdapter.Update(Me.PonyDataSet.pony_vgeneralwaybill) ... |
| 02.10.2008, 14:23 |
griefмож есть способ просто скопировать один DataTable в нужный Merge()? ... |
| 02.10.2008, 18:30 |
Попробовал... Видать слишком много записей 125 000 Очень медлено((( Всеравно спасибо! ... |
| 03.10.2008, 10:32 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1352127]: |
125ms |
32ms |
| others: | 230ms |
| total: | 419ms |
