Помогите разобраться в сортировке
У меня есть массив(текстовый файл) из 1000 строк, разбитый запятыми, вот пример строк : #,LM,Jam ID,Date Occurred,Time Jammed,Rc,Rt,Cl,Jam Text 001,03,043,04/07/15 16:02,00:00:25,00,00,00,Indexer #1 shot pin state is unknown 002,02,030,09/24/15 16:39,00:00:04,00,00,01,ATT unable to detect tray at Gripper 003,01,044,09/24/15 16:38,00:00:25,00,00,01,Main tray is hanging on guides or stuck in gripper. 004,01,044,09/24/15 16:36,00:01:51,00,01,00,Main tray is hanging on guides or stuck in gripper. 005,02,030,09/24/15 15:11,00:00:04,00,00,01,ATT unable to detect tray at Gripper 006,01,044,09/24/15 15:10,00:00:27,00,01,00,Main tray is hanging on guides or stuck in gripper. 007,01,044,09/24/15 15:10,00:00:21,00,01,00,Main tray is hanging on guides or stuck in gripper. 008,02,030,09/21/15 15:17,00:00:19,00,00,01,ATT unable to detect tray at Gripper 009,01,045,09/21/15 15:15,00:01:32,00,01,00,Aux tray is hanging on guides or stuck in gripper. 010,01,045,09/21/15 15:15,00:00:17,00,01,00,Aux tray is hanging on guides or stuck in gripper. 011,04,030,09/18/15 19:28,00:00:55,01,02,00,Missing sort device(s) on sort boat. B1 012,05,029,09/18/15 19:24,00:01:39,06,06,01,TS Picker missing parts:Ck #1 A1 013,05,016,09/18/15 19:21,00:01:12,00,01,00,Picker detects parts stuck in nests:Ck #1 A1 014,05,016,09/18/15 19:20,00:00:23,00,01,00,Picker detects parts stuck in nests:Ck #1 A1 015,05,016,09/18/15 19:17,00:01:07,02,03,00,Picker detects parts stuck in nests:Ck #1 A1 016,05,016,09/18/15 19:15,00:00:17,00,01,00,Picker detects parts stuck in nests:Ck #1 A1 017,05,029,09/18/15 01:52,00:00:18,00,01,00,TS Picker missing parts:Ck #1 A1 018,05,029,09/17/15 17:09,00:00:05,00,01,00,TS Picker missing parts:Ck #1 A1 019,05,029,09/17/15 17:05,00:00:06,00,01,00,TS Picker missing parts:Ck #1 A1 020,05,029,09/17/15 16:35,00:00:07,00,01,00,TS Picker missing parts:Ck #1 A1 021,05,029,09/17/15 15:37,00:00:08,00,01,00,TS Picker missing parts:Ck #1 A1 022,02,030,09/17/15 15:22,00:00:56,01,01,01,ATT unable to detect tray at Gripper 023,05,029,09/17/15 12:17,02:29:47,01,02,00,TS Picker missing parts:Ck #1 A1 024,02,016,09/17/15 12:25,00:02:15,02,03,00,ATT unable to open the Gripper 025,05,029,09/17/15 12:11,00:00:24,00,01,00,TS Picker missing parts:Ck #1 A1 026,05,029,09/17/15 09:50,00:00:06,00,01,00,TS Picker missing parts:Ck #1 A1 027,05,029,09/17/15 09:49,00:00:10,00,01,00,TS Picker missing parts:Ck #1 A1 028,05,015,09/17/15 09:48,00:00:04,00,01,00,Picker can't detect all parts:Ck #1 A1 029,05,015,09/17/15 09:47,00:00:05,00,01,00,Picker can't detect all parts:Ck #1 A1 Я написал LINQ запрос к нему, который считает общее время,которое складывается из поля(Time Jammed) для ошибок(позиция Jam ID) , но загвоздка в том , что для узлов всего их 6 (позиция LM), встречаются одинаковые по номеру ошибки. Как сгруппировать так чтобы он выдавал информацию номер узла номер ошибки общее время на ошибку ???? Вот мой LINQ запрос var error = (from line in readText let a = line.Split(',') where a.Length >= 5 && Regex.IsMatch(a[4], @"\d{2}:\d{2}:\d{2}") let Num = a[2] let timeAttr = a[4].Split(':') let timeUsage = TimeSpan.FromHours(int.Parse(timeAttr[0])) + TimeSpan.FromMinutes(int.Parse(timeAttr[1])) + TimeSpan.FromSeconds(int.Parse(timeAttr[2])) where timeUsage <= TimeSpan.FromHours(2) select new { Num, timeUsage } into Uzel group Uzel by Uzel.Num into g select new { Num = g.Key, TotalTime = new TimeSpan(g.Sum(arg => arg.timeUsage.Ticks)), AverageTime = new TimeSpan((long)g.Average(arg => arg.timeUsage.Ticks)) } ); ... |
| 09.10.2015, 12:01:18 |
| 09.10.2015, 12:10:58 |
Esaul9011У меня есть массив(текстовый файл) из 1000 строк, разбитый запятыми, вот пример строк : #,LM,Jam ID,Date Occurred,Time Jammed,Rc,Rt,Cl,Jam Text 001,03,043,04/07/15 16:02,00:00:25,00,00,00,Indexer #1 shot pin state is unknown 002,02,030,09/24/15 16:39,00:00:04,00,00,01,ATT unable to detect tray at Gripper 003,01,044,09/24/15 16:38,00:00:25,00,00,01,Main tray is hanging on guides or stuck in gripper. 004,01,044,09/24/15 16:36,00:01:51,00,01,00,Main tray is hanging on guides or stuck in gripper. 005,02,030,09/24/15 15:11,00:00:04,00,00,01,ATT unable to detect tray at Gripper 006,01,044,09/24/15 15:10,00:00:27,00,01,00,Main tray is hanging on guides or stuck in gripper. 007,01,044,09/24/15 15:10,00:00:21,00,01,00,Main tray is hanging on guides or stuck in gripper. 008,02,030,09/21/15 15:17,00:00:19,00,00,01,ATT unable to detect tray at Gripper 009,01,045,09/21/15 15:15,00:01:32,00,01,00,Aux tray is hanging on guides or stuck in gripper. 010,01,045,09/21/15 15:15,00:00:17,00,01,00,Aux tray is hanging on guides or stuck in gripper. 011,04,030,09/18/15 19:28,00:00:55,01,02,00,Missing sort device(s) on sort boat. B1 012,05,029,09/18/15 19:24,00:01:39,06,06,01,TS Picker missing parts:Ck #1 A1 013,05,016,09/18/15 19:21,00:01:12,00,01,00,Picker detects parts stuck in nests:Ck #1 A1 014,05,016,09/18/15 19:20,00:00:23,00,01,00,Picker detects parts stuck in nests:Ck #1 A1 015,05,016,09/18/15 19:17,00:01:07,02,03,00,Picker detects parts stuck in nests:Ck #1 A1 016,05,016,09/18/15 19:15,00:00:17,00,01,00,Picker detects parts stuck in nests:Ck #1 A1 017,05,029,09/18/15 01:52,00:00:18,00,01,00,TS Picker missing parts:Ck #1 A1 018,05,029,09/17/15 17:09,00:00:05,00,01,00,TS Picker missing parts:Ck #1 A1 019,05,029,09/17/15 17:05,00:00:06,00,01,00,TS Picker missing parts:Ck #1 A1 020,05,029,09/17/15 16:35,00:00:07,00,01,00,TS Picker missing parts:Ck #1 A1 021,05,029,09/17/15 15:37,00:00:08,00,01,00,TS Picker missing parts:Ck #1 A1 022,02,030,09/17/15 15:22,00:00:56,01,01,01,ATT unable to detect tray at Gripper 023,05,029,09/17/15 12:17,02:29:47,01,02,00,TS Picker missing parts:Ck #1 A1 024,02,016,09/17/15 12:25,00:02:15,02,03,00,ATT unable to open the Gripper 025,05,029,09/17/15 12:11,00:00:24,00,01,00,TS Picker missing parts:Ck #1 A1 026,05,029,09/17/15 09:50,00:00:06,00,01,00,TS Picker missing parts:Ck #1 A1 027,05,029,09/17/15 09:49,00:00:10,00,01,00,TS Picker missing parts:Ck #1 A1 028,05,015,09/17/15 09:48,00:00:04,00,01,00,Picker can't detect all parts:Ck #1 A1 029,05,015,09/17/15 09:47,00:00:05,00,01,00,Picker can't detect all parts:Ck #1 A1 Я написал LINQ запрос к нему, который считает общее время,которое складывается из поля(Time Jammed) для ошибок(позиция Jam ID) , но загвоздка в том , что для узлов всего их 6 (позиция LM), встречаются одинаковые по номеру ошибки. Как сгруппировать так чтобы он выдавал информацию номер узла номер ошибки общее время на ошибку ???? Вот мой LINQ запрос Код: c# 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. ); ... |
| 09.10.2015, 12:15:31 |
А это можно по русски? Esaul9011Я написал LINQ запрос к нему, который считает общее время,которое складывается из поля(Time Jammed) для ошибок(позиция Jam ID), но загвоздка в том , что для узлов всего их 6 (позиция LM), встречаются одинаковые по номеру ошибки. Как сгруппировать так чтобы он выдавал информацию номер узла номер ошибки общее время на ошибку ???? Вот мой LINQ запрос ... |
| 15.10.2015, 10:55:41 |
start [/forum/topic.php?fid=17&gotonew=1&tid=1349484]: |
163ms |
46ms |
| others: | 199ms |
| total: | 470ms |
