Pascal
Privet wsem! Moget kto znaet, kak perevesti string v integer w Pascale ili xotja bi kak rabotaet funktija Val? ... |
| 27.10.2002, 13:17:40 |
Pascal
Код: plaintext 1. 2. 3. Code - simvol, na kotorom voznikla oshibka (esli stroka sogerzit nechislovie simvoli) Esli ti v Dephi, to tam est takaya functia StrToInt(s: string): integer preobrazuet stroky v celoe chislo, esli ne ono ne preobrazuetsa - generit Exception Help po val is Dephi: Converts a string to a numeric representation. Unit System Category string handling routines procedure Val(S; var V; var Code: Integer); Description Val converts the string value S to its numeric representation, as if it were read from a text file with Read. S is a string-type expression; it must be a sequence of characters that form a signed real number. V is an integer-type or real-type variable. If V is an integer-type variable, S must form a whole number. Code is a variable of type Integer. If the string is invalid, the index of the offending character is stored in Code; otherwise, Code is set to zero. For a null-terminated string, the error position returned in Code is one larger than the actual zero-based index of the character in error. Val performs range checking differently depending upon the setting of the $R compiler directive and the type of the parameter V. ... |
| 28.10.2002, 10:45:20 |
start [/forum/topic.php?fid=16&gotonew=1&tid=1348993]: |
173ms |
23ms |
| others: | 230ms |
| total: | 457ms |
