А есть такая API функция???
Завершить сеанс активного пользованеля в WinXP. Есть ли такая API функция? ... |
| 01.02.2004, 20:23:33 |
The ExitWindowsEx function either logs off, shuts down, or shuts down and restarts the system. BOOL ExitWindowsEx( UINT uFlags, // shutdown operation DWORD dwReserved // reserved ); Parameters uFlags Specifies the type of shutdown. This parameter must be some combination of the following values: Value Meaning EWX_FORCE Forces processes to terminate. When this flag is set, Windows does not send the messages WM_QUERYENDSESSION and WM_ENDSESSION to the applications currently running in the system. This can cause the applications to lose data. Therefore, you should only use this flag in an emergency. EWX_LOGOFF Shuts down all processes running in the security context of the process that called the ExitWindowsEx function. Then it logs the user off. EWX_POWEROFF Shuts down the system and turns off the power. The system must support the power-off feature.Windows NT: The calling process must have the SE_SHUTDOWN_NAME privilege. For more information, see the following Remarks section. Windows 95: Security privileges are not supported or required. EWX_REBOOT Shuts down the system and then restarts the system. Windows NT: The calling process must have the SE_SHUTDOWN_NAME privilege. For more information, see the following Remarks section. Windows 95: Security privileges are not supported or required. EWX_SHUTDOWN Shuts down the system to a point at which it is safe to turn off the power. All file buffers have been flushed to disk, and all running processes have stopped. Windows NT: The calling process must have the SE_SHUTDOWN_NAME privilege. For more information, see the following Remarks section. Windows 95: Security privileges are not supported or required. dwReserved Reserved; this parameter is ignored. Return Values If the function succeeds, the return value is nonzero. If the function fails, the return value is zero. To get extended error information, call GetLastError. Remarks The ExitWindowsEx function returns as soon as it has initiated the shutdown. The shutdown or logoff then proceeds asynchronously. During a shutdown or log-off operation, applications that are shut down are allowed a specific amount of time to respond to the shutdown request. If the time expires, Windows displays a dialog box that allows the user to forcibly shut down the application, to retry the shutdown, or to cancel the shutdown request. If the EWX_FORCE value is specified, Windows always forces applications to close and does not display the dialog box. The ExitWindowsEx function sends a separate notification message, CTRL_SHUTDOWN_EVENT or CTRL_LOGOFF_EVENT as the situation warrants, to console processes. A console process routes these messages to its HandlerRoutine functions, which are added and removed by calls to the SetConsoleCtrlHandler function. ExitWindowsEx sends these notification messages asynchronously; thus, an application cannot assume that the console notification messages have been handled when a call to ExitWindowsEx returns. Windows NT: To shut down or restart the system, the calling process must use the AdjustTokenPrivileges function to enable the SE_SHUTDOWN_NAME privilege. ... |
| 01.02.2004, 21:27:27 |
start [/forum/topic.php?fid=16&gotonew=1&tid=1348570]: |
69ms |
51ms |
76ms |
| others: | 222ms |
| total: | 467ms |
