NLS ili chto-to drugoe
Estj prilozhenie na Windows NT ispoljzujus4aja bde pri obras4enii k paradox db, pripisanoj v ODBC (system DSN,Microsoft Paradox driver(*.db) v prilozhenii estj sql takogo tipa select field1 from table1 where field2="Var" I vot v odin moment ... ne znaju s 4em svjazanno perestal rabotatj etot sql ne ho4et bratj kavi4ki (") a rabotaet toljko v variante apostrofov select field1 from table1 where field2='Var', kak iz prilozhenija taki ldja proverki iz SQL Explorera. Ja tak ponimaju 4to eto 4to-to slu4ilosj s NLS ustanovkami... Mozhet podskazhete kak eto le4itsja? ... |
| 23.03.2004, 10:49:42 |
start [/forum/search_topic.php?author=SimplTsar&author_mode=last_topics&do_search=1]: |
57ms |
28ms |
| others: | 753ms |
| total: | 901ms |
