Форумы / Программирование [игнор отключен] [закрыт для гостей] / АSP.NET DEVELOPMENT SERVER
4 сообщений из 4, страница 1 из 1
    #36845827
botokiller
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception (0x80004005): Не удается найти указанный файл
at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
at Microsoft.VisualStudio.WebServer.WebServerForm_DAL.DoLaunch()
at Microsoft.VisualStudio.WebServer.WebServerForm_DAL.OnLinkClickedHyperlinkLinkLabel(Object sender, LinkLabelLinkClickedEventArgs e)
at System.Windows.Forms.LinkLabel.OnLinkClicked(LinkLabelLinkClickedEventArgs e)
at System.Windows.Forms.LinkLabel.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Label.WndProc(Message& m)
at System.Windows.Forms.LinkLabel.WndProc(Message& msg)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30128.1 (RC1Rel.030128-0100)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30128/mscorlib.dll
WebDev.WebServer40
Assembly Version: 10.0.0.0
Win32 Version: 10.0.30128.1
CodeBase: file:///C:/Program%20Files/Common%20Files/Microsoft%20Shared/DevServer/10.0/WebDev.WebServer40.exe
WebDev.WebHost40
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/WebDev.WebHost40/v4.0_10.0.0.0__b03f5f7f11d50a3a/WebDev.WebHost40.dll
Win32 Version: 4.0.30128.1 built by: RC1Rel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Web
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
что делать???
выдает ошибку и работать не хочет!!
    #36845836
rstudio
вы пробовали включить и выключить компьютер ? (с)It Crowd
    #36845885
botokiller
rstudio,
sps
    #36846520
Фотография tchingiz
авторНе удается найти указанный файл
а на каком это по белому написано?
