Не устанавливается Visual Studio 2005
[02/19/11,23:25:06] Microsoft Document Explorer 2005: [2] Error code 1603 for this component means "В процессе установки произошла неисправимая ошибка. " [02/19/11,23:25:06] Microsoft Document Explorer 2005: [2] Setup Failed on component Microsoft Document Explorer 2005 [02/19/11,23:25:06] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() with HRESULT -2147023293. [02/19/11,23:25:06] setup.exe: [2] Component error string not specified in ISetupManager::AddToActionResultCollection() [02/19/11,23:25:09] VS70pgui: [2] DepCheck indicates Microsoft Document Explorer 2005 is not installed. [02/19/11,23:25:09] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2005 Professional Edition - ENU was not attempted to be installed. [02/19/11,23:25:09] VS70pgui: [2] Unknown component status for.NET Compact Framework 1.0 SP3 [02/19/11,23:25:09] VS70pgui: [2] Unknown component status for.NET Compact Framework 2.0 [02/19/11,23:25:09] VS70pgui: [2] Unknown component status forMicrosoft Visual J# 2.0 Redistributable Package [02/19/11,23:25:09] VS70pgui: [2] Unknown component status forSQL Server 2005 Mobile Edition [02/19/11,23:25:09] VS70pgui: [2] Unknown component status forMicrosoft Device Emulator version 1.0 [02/19/11,23:25:09] VS70pgui: [2] Unknown component status forMicrosoft SQL Server 2005 Express Edition x86 [02/19/11,23:41:51] Microsoft Document Explorer 2005: [2] Error code 1603 for this component means "В процессе установки произошла неисправимая ошибка. " [02/19/11,23:41:51] Microsoft Document Explorer 2005: [2] Setup Failed on component Microsoft Document Explorer 2005 [02/19/11,23:42:11] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() with HRESULT -2147023293. [02/19/11,23:42:11] setup.exe: [2] Component error string not specified in ISetupManager::AddToActionResultCollection() [02/19/11,23:50:27] Microsoft Document Explorer 2005: [2] Error code 1603 for this component means "В процессе установки произошла неисправимая ошибка. " [02/19/11,23:50:27] Microsoft Document Explorer 2005: [2] Setup Failed on component Microsoft Document Explorer 2005 [02/19/11,23:50:47] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() with HRESULT -2147023293. [02/19/11,23:50:47] setup.exe: [2] Component error string not specified in ISetupManager::AddToActionResultCollection() [02/19/11,23:54:12] Microsoft Document Explorer 2005: [2] Error code 1603 for this component means "В процессе установки произошла неисправимая ошибка. " [02/19/11,23:54:12] Microsoft Document Explorer 2005: [2] Setup Failed on component Microsoft Document Explorer 2005 [02/19/11,23:54:33] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() with HRESULT -2147023293. [02/19/11,23:54:33] setup.exe: [2] Component error string not specified in ISetupManager::AddToActionResultCollection() [02/20/11,00:02:44] VS70pgui: [2] DepCheck indicates Microsoft Document Explorer 2005 is not installed. [02/20/11,00:02:44] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2005 Professional Edition - ENU was not attempted to be installed. [02/20/11,00:02:44] VS70pgui: [2] Unknown component status for.NET Compact Framework 1.0 SP3 [02/20/11,00:02:44] VS70pgui: [2] Unknown component status for.NET Compact Framework 2.0 [02/20/11,00:02:44] VS70pgui: [2] Unknown component status forMicrosoft Visual J# 2.0 Redistributable Package [02/20/11,00:02:44] VS70pgui: [2] Unknown component status forSQL Server 2005 Mobile Edition [02/20/11,00:02:44] VS70pgui: [2] Unknown component status forMicrosoft Device Emulator version 1.0 [02/20/11,00:02:44] VS70pgui: [2] Unknown component status forMicrosoft SQL Server 2005 Express Edition x86 [02/20/11,01:13:27] Microsoft Document Explorer 2005: [2] Error code 1603 for this component means "В процессе установки произошла неисправимая ошибка. " [02/20/11,01:13:27] Microsoft Document Explorer 2005: [2] Setup Failed on component Microsoft Document Explorer 2005 [02/20/11,01:13:47] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() with HRESULT -2147023293. [02/20/11,01:13:47] setup.exe: [2] Component error string not specified in ISetupManager::AddToActionResultCollection() [02/20/11,01:20:58] VS70pgui: [2] DepCheck indicates Microsoft Document Explorer 2005 is not installed. [02/20/11,01:20:58] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2005 Professional Edition - ENU was not attempted to be installed. [02/20/11,01:20:58] VS70pgui: [2] Unknown component status for.NET Compact Framework 1.0 SP3 [02/20/11,01:20:58] VS70pgui: [2] Unknown component status for.NET Compact Framework 2.0 [02/20/11,01:20:58] VS70pgui: [2] Unknown component status forSQL Server 2005 Mobile Edition [02/20/11,01:20:58] VS70pgui: [2] Unknown component status forMicrosoft Device Emulator version 1.0 [02/20/11,12:55:30] Microsoft Document Explorer 2005: [2] Error code 1603 for this component means "В процессе установки произошла неисправимая ошибка. " [02/20/11,12:55:31] Microsoft Document Explorer 2005: [2] Setup Failed on component Microsoft Document Explorer 2005 [02/20/11,12:55:31] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() with HRESULT -2147023293. [02/20/11,12:55:31] setup.exe: [2] Component error string not specified in ISetupManager::AddToActionResultCollection() [02/20/11,12:55:34] VS70pgui: [2] DepCheck indicates Microsoft Document Explorer 2005 is not installed. [02/20/11,12:55:34] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2005 Professional Edition - ENU was not attempted to be installed. [02/20/11,12:55:34] VS70pgui: [2] Unknown component status for.NET Compact Framework 1.0 SP3 [02/20/11,12:55:34] VS70pgui: [2] Unknown component status for.NET Compact Framework 2.0 [02/20/11,12:55:34] VS70pgui: [2] Unknown component status forMicrosoft Visual J# 2.0 Redistributable Package [02/20/11,12:55:34] VS70pgui: [2] Unknown component status forSQL Server 2005 Mobile Edition [02/20/11,12:55:34] VS70pgui: [2] Unknown component status forMicrosoft Device Emulator version 1.0 [02/20/11,12:55:34] VS70pgui: [2] Unknown component status forMicrosoft SQL Server 2005 Express Edition x86 [02/20/11,13:10:11] Microsoft Document Explorer 2005: [2] Error code 1603 for this component means "В процессе установки произошла неисправимая ошибка. " [02/20/11,13:10:11] Microsoft Document Explorer 2005: [2] Setup Failed on component Microsoft Document Explorer 2005 [02/20/11,13:10:11] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InstallManagerHelper() with HRESULT -2147023293. [02/20/11,13:10:11] setup.exe: [2] Component error string not specified in ISetupManager::AddToActionResultCollection() [02/20/11,13:10:13] VS70pgui: [2] DepCheck indicates Microsoft Document Explorer 2005 is not installed. [02/20/11,13:10:13] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2005 Professional Edition - ENU was not attempted to be installed. [02/20/11,13:10:13] VS70pgui: [2] Unknown component status for.NET Compact Framework 1.0 SP3 [02/20/11,13:10:13] VS70pgui: [2] Unknown component status for.NET Compact Framework 2.0 [02/20/11,13:10:13] VS70pgui: [2] Unknown component status forSQL Server 2005 Mobile Edition [02/20/11,13:10:13] VS70pgui: [2] Unknown component status forMicrosoft Device Emulator version 1.0 в чем проблема? ... |
| 20.02.2011, 14:17 |
Андрей1989, может проще найти другой дистрибутив к примеру с более новой 2008 студией ... |
| 20.02.2011, 14:50 |
Компоненты все присутствуют? Причём уже не первое десятилетие, например, Office уже считается не просто приложением, а фактически «дополнением» к Windows, и его компоненты используются очень многими приложениями. Недаром же практически невозможно купить компьютер с предустановленной Windows и без предустановленного Office-а... ... |
| 20.02.2011, 16:15 |
Сергей СилкинНедаром же практически невозможно купить компьютер с предустановленной Windows и без предустановленного Office-а... та ну? я ни одного не видел с предустановленным офисом. везде голая винда. ... |
| 20.02.2011, 18:03 |
Сергей Силкин, какие именно компоненты? эту же студию ставил на другой ноут,и там все хорошо поставилось. а у меня вообще ничего не хочет.. ... |
| 20.02.2011, 18:31 |
А может стоит Vista или 7 и поэтому не хочет устанавливаться? ... |
| 20.02.2011, 19:46 |
Сергей СилкинНедаром же практически невозможно купить компьютер с предустановленной Windows и без предустановленного Office-а ... Это бред сивой кобылы! Может быть установили по-желанию. Всегда ставят только голую винду. ... |
| 20.02.2011, 19:47 |
Андрей1989, либо сама система глючная, либо VS2005 глючная ... |
| 20.02.2011, 21:17 |
| 20.02.2011, 22:32 |
start [/forum/topic.php?fid=16&fpage=89&tid=1343131]: |
50ms |
60ms |
| others: | 306ms |
| total: | 460ms |
