Приложение MDS
При запуске web приложения MDS вылезает такое: Подскажите пожалуйста что с этим сделать. Server Error in '/' Application. -------------------------------------------------------------------------------- Runtime Error Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed. Details: To enable the details of this specific error message to be viewable on the local server machine, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "RemoteOnly". To enable the details to be viewable on remote machines, please set "mode" to "Off". <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly"/> </system.web> </configuration> Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL. <!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="On" defaultRedirect="mycustompage.htm"/> </system.web> </configuration> Модератор: Тема перенесена из форума "Microsoft SQL Server". ... |
| 21.08.2012, 18:28:56 |
Приложение MDS
Уважаемые програмисты, подскажите пожалуйста. ... |
| 22.08.2012, 14:11:37 |
Приложение MDS
Тебе же вполне вменяемо пишут: kornilovDetails: To enable the details of this specific error message to be viewable on the local server machine, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "RemoteOnly". To enable the details to be viewable on remote machines, please set "mode" to "Off". Трудно перевести? ... |
| 22.08.2012, 15:14:47 |
start [/forum/topic.php?fid=16&fpage=65&tid=1342162]: |
37ms |
42ms |
| others: | 200ms |
| total: | 315ms |
