Форумы / Программирование [игнор отключен] [закрыт для гостей] / Проблемы C# и Yandex Locator API
2 сообщений из 2, страница 1 из 1
    #38200412
StalkerKG
Нужно получать координаты текущего местоположения, юзаю Я. Локатор.
Код: c#
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
using System;
using System.IO;
using System.Text;
using System.Xml;
using System.Net;
using System.Xml.Serialization;
using System.Xml.Linq;
using Android.Telephony;
using Android.Widget;
namespace TrackingApp
	public class DataXmlGenerator
		private static DataXmlGenerator m_XMLGenerator = new DataXmlGenerator();
		private static dynamic YaLocator = new
			Version = "1.0",
			ApiKey = @"AB8KN1EBAAAAt-_0awMAtvZAzciQJO3iFHMvHyCRkBhG0mcAAAAAAAAAAACIqk6bjAfT-oQaEeb9uU8Cavl2-g==",
			CountryCode = 250,
			OperatorId = 1,
			CellId = 12,
			Lac = 6405,
			SignalStrengthGsm = -45,
			SignalStrengthWiFi = -90,
			Age = 1000,
			Mac = "0123456789AB",
			IP = "37.218.149.199"
		private DataXmlGenerator ()
		public static DataXmlGenerator GetInstance()
			return m_XMLGenerator;
		public void XMLsender()
			System.Net.ServicePointManager.Expect100Continue = false;
			var req = (HttpWebRequest)WebRequest.Create("http://api.lbs.yandex.net/geolocation");
			req.Method = WebRequestMethods.Http.Post;
			req.ContentType = "application/x-www-form-urlencoded";
			req.Headers[HttpRequestHeader.AcceptEncoding] = "identity";
			var xDoc = new XDocument(
				new XElement("ya_lbs_request",
			             new XElement("common",
			             new XElement("version", YaLocator.Version),
			             new XElement("api_key", YaLocator.ApiKey)),
			             new XElement("gsm_cells",
			             new XElement("countrycode", YaLocator.CountryCode),
			             new XElement("operatorid", YaLocator.OperatorId),
			             new XElement("cellid", YaLocator.CellId),
			             new XElement("lac", YaLocator.Lac),
			             new XElement("signal_strength", YaLocator.SignalStrengthGsm),
			             new XElement("age", YaLocator.Age)),
			             new XElement("wifi_networks",
			             new XElement("network",
			             new XElement("mac", YaLocator.Mac),
			             new XElement("signal_strength", YaLocator.SignalStrengthWiFi))),
			             new XElement("ip",
			             new XElement("address_v4", YaLocator.IP))));
			var sentData = System.Text.Encoding.UTF8.GetBytes(string.Format("xml={0}", xDoc.ToString()));
			req.ContentLength = sentData.Length;
			using (var sendStream = req.GetRequestStream())
				sendStream.Write(sentData, 0, sentData.Length);
			var response = (HttpWebResponse)req.GetResponse();
			var buf = new byte[response.ContentLength];
			using (var respStream = response.GetResponseStream())
				respStream.Read(buf, 0, buf.Length);
				string m = System.Text.Encoding.UTF8.GetString(buf);
Вот по этому коду передаю, получаю, только загвоздка вот в чем тут: http://habrahabr.ru/company/yandex/blog/114491/ у людей все работает, у меня падает с 404 ошибкой
Код: c#
1.
Уже голова пухнет почему он так делает, ссылки вроде все норм, можете подсказать ребят где я ошибку допускаю... =(
Заранее очень благодарен!
    #38201581
sld
sld
статье уже больше двух лет могло чонить и поменяться в api.
