Тестовые задачки на логику и не только
Всем привет. На собеседование дали тест, который я конечно же завалил, но к сожалению подробно ничего не объяснили, поэтому все же интересно узнать правильные решения. Выкладываю задачки - может кому интересно будет порешать :) Question # 1 Julia states: “When I went fishing the other day, every fish that I caught was a tuna, and every tuna I saw I caught.” Of the following statements listed below, which one can be concluded from the observations of Julia? A. Tuna was the only fish that Julia saw while she was fishing. B. While Julia was fishing, no other fish were caught by her. C. In the area that Julia fished, there were no other fish. D. All of the fish that Julia saw she caught. E. Julia did not see any other fish while she was fishing Question # 2 Suppose you and I have the same amount of money. How much must I give you so that you have ten dollars more than I? Question # 3 A dealer bought an article for $7, sold it for $8, bought it back for $9, and sold it for $10. How much profit did he make? Question # 4 Imagine that you have a client that has a UI for reviewing his many thousands of orders, 50 per page. The UI also allows the client to limit the orders based on the current status of the order. The orders are in a database table called [ORDERS] with a numeric, incrementing primary key named [ORDER_ID]. The table also has a column [ORDER_STATUS] with three possible values: “PROCESSING” “COMPLETED” “CANCELLED” Please write out a SQL statement that will output the third page of “CANCELLED” orders (the 101-150th cancelled orders). Bear in mind that while the [ORDER_ID] values are probably sequential in the database, the [ORDER_ID] values for the “CANCELLED” orders are not. Please use ONLY SQL and avoid vendor specific SQL commands (such as MS SQL’s RowID() or MySQL’s limit). Question # 5 500 men are arranged in an array of 10 rows and 50 columns according to their heights. The tallest man in each row is asked to come out and the shortest among them is A. After resuming their original positions, the shortest among each column is asked to come out and the tallest among them is B. Who is taller, A or B ? Question # 6 You have 26 constants, labeled A through Z. Let A equal 1. The other constants have values equal to the letter's position in the alphabet, raised to the power of the previous constant. That means that B (the second letter) = 2^A = 2^1 = 2 C (the third letter) = 3^B = 3^2 = 9 The value for this expression: (X-A) * (X-B) * (X-C) * ... * (X-Y) * (X-Z) will A. Fit into an Int32 B. Fit into an Int64 C. Not fit into either Question # 7 On the popular children's television show, the "Faboo Foursome" are four cartoon animals. Since they are cartoons, when they are on tour, each is represented by a puppet that is operated by a chief and an assistant puppeteer. The types of animals are: Camel, Koala, Kangaroo, and Cobra The animal's names are: Audrey, Alan, Andrew, Anthony The Chief Puppeteers are: Ben, Brenda, Brian and Britney The Assistant Puppeteers are: Dave, Diane, Debby and Drew 1. Andrew isn’t the puppet who is operated by Britney and her assistant Debby. 2. Alan’s chief puppeteer (who is not Brenda) is assisted by Drew. 3. Ben is in charge of the camel, but Brenda doesn’t have anything to do with the kangaroo. 4. Dave is the assistant puppeteer for the cobra. 5. Anthony, whose chief is Brian, isn’t the koala (whose name is not Andrew). What is the name of the camel? How do you know? A. Audrey B. Alan C. Andrew D. Anthony E. Arthur Question # 8 You have just been assigned to a new team and your project manager sends you an email: “We need you to design a database schema and build a UI that will handle the task management day to day of our development team. We currently manage our tasks in excel and by email and it’s no longer working. Please send me the schema for review when it’s ready.” What are some of your first steps? 1. If you are going to look at things you know, please list them by name. 2. If you are going to come back with questions, please list them. мои ответы 1. B 2. 5$ 3. 2$ 4. - 5. A or same 6. C 7. B 8. - ... |
| 27.09.2013, 21:12:14 |
Да ладно врать-то... собеседование... с которого ты вынес вопросы в электронном виде, да на аглицком... ... |
| 27.09.2013, 21:31:06 |
Akina, В смысле? Что куда откуда вынес? Все ж удаленно. Прислали файл с задачами, дали время, ну вот и тест. ... |
| 27.09.2013, 21:33:57 |
Ну а тогда гугль в помощь. Задания находятся на счёт раз. Вместе с ответами. PS. Не надо говорить "сам попробуй" - я проверил. Находятся. ... |
| 27.09.2013, 22:32:12 |
Шестое задание улыбнуло. Недавно участвовал в викторине, где нужно было за 10 секунд ответить, чему равно произведение всех арабских цифр. ... |
| 28.09.2013, 13:48:15 |
MozokШестое задание улыбнуло. Недавно участвовал в викторине, где нужно было за 10 секунд ответить, чему равно произведение всех арабских цифр.:) А автор не сообразил, что X идёт перед Y и Z. ... |
| 29.09.2013, 00:40:07 |
Блджад да откуда вы тут все такие аппер индермедиейт. Для меня это тест по английскому а не на логику. Перевести-б... ... |
| 29.09.2013, 01:57:52 |
skyANAА автор не сообразил, что X идёт перед Y и Z. В смысле ответ на #6 - 0, по причине наличия ... * (X - X) *...? Хорошо, а как все-таки зовут "Камеля" (с)? ... |
| 29.09.2013, 02:07:11 |
Если бы мне дали такие задачки, я бы в первую очередь спросил бы их, как это все относится к программированию и разработке по. Мне было бы стыдно давать такие задачки людям. ... |
| 29.09.2013, 09:24:48 |
_nautilus_ Question # 4 avoid vendor specific SQL commands (such as MS SQL’s RowID() or MySQL’s limit). Порадовало. ... |
| 29.09.2013, 13:37:39 |
_nautilus_Хорошо, а как все-таки зовут "Камеля" (с)? Arthur . ... |
| 29.09.2013, 17:47:55 |
Mozok_nautilus_Хорошо, а как все-таки зовут "Камеля" (с)? Arthur . А почему Артур? Я вообще вот так решал: Brian -> Anthony => Camel in (Audrey || Alan || Andrew) Brian -> Anthony => Anthony in (Kangaroo || Cobra) (Anthony != Koala) && (Andrew != Koala) => Koala in (Audrey || Alan) (Ben -> Camel) && (Brian -> Anthony) => Brian in (Kangaroo || Cobra) (Ben -> Camel) && (Brenda !kangaroo) => Brenda in (Koala || Cobra) Britney -> (Koala || Kangaroo || Cobra) not Andrew Dave -> (!Ben && !Britney) => (Brenda && Brian) Drew -> (!Britney && !Brenda) => (Ben && Brian) (Brian -> Anthony) => Drew -> Ben => Camel's name is Alan Koala's name is Audrey (Britney -> !Andrew) && (Brian -> Anthony) && (Ben -> Camel) => Britney -> Audrey Britney -> Koala Ben -> Camel (Brenda -> !kangaroo) && Brian -> Anthony (Kangaroo || Cobra) => Brenda -> Cobra Cobra's name is Andrew Dave -> Brenda и вот шо вышло в итоге: Drew Ben Camel (Alan) Debby Britney Koala (Audrey) Dave Brenda Cobra (Andrew) Diane Brian Kangaroo (Anthony) ... |
| 29.09.2013, 19:24:58 |
MasterZivМне было бы стыдно давать такие задачки людям. Да ладно, зато задачки прикольные. На логику и все такое. По идее должны показывать насколько быстро претендент шевелит мозгами и если есть изначально неверный посыл в задаче, мог быстро это выявить. Ведь по сути умение быстро и четко вращать шариками, способность предельно концентрироваться и хороший английский - ключевые черты программиста выше среднего уровня. А указатели, кучи и прочее в таком анализе вещи второго порядка. ... |
| 29.09.2013, 19:33:36 |
_nautilus_MasterZivМне было бы стыдно давать такие задачки людям. Да ладно, зато задачки прикольные. На логику и все такое. По идее должны показывать насколько быстро претендент шевелит мозгами и если есть изначально неверный посыл в задаче, мог быстро это выявить. Ведь по сути умение быстро и четко вращать шариками, способность предельно концентрироваться и хороший английский - ключевые черты программиста выше среднего уровня. А указатели, кучи и прочее в таком анализе вещи второго порядка. Это что?? Тест на работу в главное развед-управление? Я-бы вообще поостерегался вводить в собеседование подобные тесты. Мы рискуем вместо штата программистов получить штат не умеющих программить лингвистов или переводчиков (нужное подчеркните). И думайте сами кто вам больше нужен в работе. Нам как-то один профессор физ-мата сказал что он по современным тестам IQ набирает меньше баллов чем его студенты. Ну и какие выводы? P.S. Я если чо не могу телефон -значный запомнить. Ну... даже запомню 10 цифр (пока набираю на клавиатуре) то после этого через 2 минуты - всё. Меня можно пытать - хер я чего вспомню. Временная память - как /dev/null. Улетело в никуда. P.P.S. И задачу Эйнштейна без бумажки не решу. ... |
| 29.09.2013, 21:50:44 |
maytonЭто что?? Тест на работу в главное развед-управление?...штат не умеющих программить лингвистов или переводчиков Нет. Просто нужен был программер для западной конторы. Соответственно английский еще более в приоритете. maytonЯ-бы вообще поостерегался вводить в собеседование подобные тесты Ну пока единая стандартизация отсутствует и в каждой конторе пестуют собственное просветленное кунфу, соответственно и методику тестирования каждый выбирает какую нравится. maytonНам как-то один профессор физ-мата сказал что он по современным тестам IQ набирает меньше баллов чем его студенты. Ну и какие выводы? Выводы простые. Если б на работе от меня потребовали регулярно проходить такие тесты - начал бы тренироваться либо сменил работу. Пока не требует - как-то положить на тесты IQ. Ок. А кто как ответил на 1 вопрос? Тут вообще просто формальная логика. ... |
| 30.09.2013, 01:39:22 |
_nautilus_, да там и неформальной хватит, чтобы отмести все ответы, кроме второго, если, конечно, "no other" там означает "only tuna" :) ... |
| 30.09.2013, 05:16:07 |
tanglir_nautilus_, да там и неформальной хватит, чтобы отмести все ответы, кроме второго, если, конечно, "no other" там означает "only tuna" :) Да, вот я тож так полумал. По идее оно не может означать ничего окромя "only tuna" ... |
| 01.10.2013, 03:53:12 |
start [/forum/topic.php?fid=16&fpage=52&tid=1341646]: |
33ms |
| others: | 195ms |
| total: | 285ms |
