ARj (ключ на перезапись без вопроса) или Del *.* (без вопроса)
Помогите пожалуйста ! Нужно извлечь из архива и перезаписать файлы в Bat-файле с помощью ARj x ..... (ключ на перезапись без вопроса) или Del *.* (без вопроса на перезапись). Спасибо. ... |
| 19.04.2004, 15:42:30 |
del *.*? ARj x -y ... |
| 19.04.2004, 16:10:18 |
del *.* /Q eNose ... |
| 19.04.2004, 17:27:26 |
List of frequently used commands and switches. Type ARJ32 -? for more help. Usage: ARJ32 <command> [-<sw> [-<sw>...]] <archive_name> [<file_names>...] Examples: ARJ32 a -e archive, ARJ e archive, ARJ l archive *.doc <Commands> ac: Add Chapter to chapter archive l: List contents of archive a: Add files to archive m: Move files to archive c: Comment archive files t: Test integrity of archive d: Delete files from archive u: Update files to archive e: Extract files from archive v: Verbosely list contents of archive f: Freshen files in archive x: eXtract files with full pathname <Switches> c: skip time-stamp Check r: Recurse subdirectories e: Exclude paths from names s: set archive time-Stamp to newest f: Freshen existing files u: Update files (new and newer) g: Garble with password v: enable multiple Volumes i: with no progress Indicator w: assign Work directory m: with Method 0, 1, 2, 3, 4 x: eXclude selected files n: only New files (not exist) y: assume Yes on all queries ... |
| 20.04.2004, 19:27:29 |
start [/forum/topic.php?fid=16&fpage=223&tid=1348462]: |
84ms |
37ms |
| others: | 217ms |
| total: | 387ms |
