Kak mojon zpustit NASM na Windows XP
Zdravstvuyte Lyudi Dobrie !!! Ya xochu izuchit assmbler i uje znayu mnogo kommand. No ya vse delayu teoricheski, potomu chto ne mogu ustonovit NASM na svoy PC (OS WIN XP). Skajite pojalusta gde ya mogu skachat programmu (compiler, linker) dlya Windows. Ili kak ya mogu instolirovat NASM na Win XP (ya postavlyu na root directory ona otkrivaetsa i srazu zakrivaetsa. Eto tak kak kto ta vvodit telnet na Run prompte okno otkrivaetsa i srazu zakrivaetsa) Pojalusta pomogite S uvajeniem Eectronshik ... |
| 06.12.2005, 13:36 |
Use www.yandex.ru type: windows assembler or type:wasm press ENTER example: www.wasm.ru ... |
| 06.12.2005, 13:50 |
Thank u * Alk for reply ! But i need how to do instruction to install and run NASM on Windows XP. Ive downloaded NASM and PASM. But i can neither run PASM, NOR NASM :( ... |
| 06.12.2005, 14:12 |
юзай FASM, насм - это классика офкос, но стоит попробовать и ФАСМ. Have u seen Масм32? If not try right now. И пиши на русском!!! ... |
| 06.12.2005, 14:42 |
Why do U need NASM insted of use MASM all of them have similar syntax masm - is traditionall compiller under windows (don't Use tasm or any...) so... in documens(I have only NASM 0.98) there is: 1.3.1 Installing NASM under MS-DOS or Windows Once you've obtained the DOS archive for NASM, `nasmXXX.zip' (where `XXX' denotes the version number of NASM contained in the archive), unpack it into its own directory (for example `c:\nasm'). The archive will contain four executable files: the NASM executable files `nasm.exe' and `nasmw.exe', and the NDISASM executable files `ndisasm.exe' and `ndisasmw.exe'. In each case, the file whose name ends in `w' is a Win32 executable, designed to run under Windows 95 or Windows NT Intel, and the other one is a 16-bit DOS executable. The only file NASM needs to run is its own executable, so copy (at least) one of `nasm.exe' and `nasmw.exe' to a directory on your PATH, or alternatively edit `autoexec.bat' to add the `nasm' directory to your `PATH'. (If you're only installing the Win32 version, you may wish to rename it to `nasm.exe'.) That's it - NASM is installed. You don't need the `nasm' directory to be present to run NASM (unless you've added it to your `PATH'), so you can delete it if you need to save space; however, you may want to keep the documentation or test programs. If you've downloaded the DOS source archive, `nasmXXXs.zip', the `nasm' directory will also contain the full NASM source code, and a selection of Makefiles you can (hopefully) use to rebuild your copy of NASM from scratch. The file `Readme' lists the various Makefiles and which compilers they work with. Note that the source files `insnsa.c', `insnsd.c', `insnsi.h' and `insnsn.c' are automatically generated from the master instruction table `insns.dat' by a Perl script; the file `macros.c' is generated from `standard.mac' by another Perl script. Although the NASM 0.98 distribution includes these generated files, you will need to rebuild them (and hence, will need a Perl interpreter) if you change `insns.dat', `standard.mac' or the documentation. It is possible future source distributions may not include these files at all. Ports of Perl for a variety of platforms, including DOS and Windows, are available from www.cpan.org. ... |
| 06.12.2005, 14:48 |
Borya spasibo za otvet !!! No delo vtom chto v techenie etoy nedeli ya uje skachal gde to 5 assemblerov. Xot kto to skajet mne kakuyu versuyu ya doljen skachat i napisat tam MOV ax, 100 MOV bx, 120 ADD ax, bx i togdali !!!! Ya tolko xochu izuchit assembler !!! V asnovnom ya progarmiruyu na C++ Builder 6. Vot mujiki delali IDE i ne prixoditsa iskat compiler, linker i togdali !!! A vot s assemblerom Ya xochu tochno takoy paket kotoriy pozvolit mne zdelat vse za raz. Napisal programmu, skompliroval a potom dva raza najal na exe modul i VSE Elektronshik ... |
| 06.12.2005, 14:51 |
Рекомендую masm32 если хочешь кодить в Winde32, мощный макроязык плюс куча инков, все-таки легендарный масм. Потом нужен хороший ИДЕ, советую RadASM, поддерживает вплоть до НАСМа. А вот Фасм - он тоже хорош тем более интенсивно развивается, неплохая макроинфра, кроме PE он и линуху поддерживает (elf). Кароче если собрался под виндой на интель, рекомендую масм32. ... |
| 06.12.2005, 14:59 |
Spasibo Borya !!! A mojno ya nachnu na FASM-e !!! Na samom dele ya predpochitayu C++ i budu na nem rabotat !! No ya tak xochu izuchit sistemnie resursi PC i eshe yesli kto to znaet assembler to yemu legche budut i na C, C++ ili Delphi I posledniy Ya electronshik i sobirayus izuchit PIC. Uje est nikaya praktika i izuchenie assembler dlya Intel uskorit i oblegchit moyu zadachu !! Elektronshik ... |
| 06.12.2005, 15:13 |
start [/forum/topic.php?fid=16&fpage=192&tid=1347233]: |
138ms |
49ms |
| others: | 245ms |
| total: | 477ms |
