Помогите пожалуйста... кто сможет.
Есть vb скрипт: Function Main() Dim oCmd, sSQL, oDom ''' If MSXML 4.0 is not installed this will not work! Set oDom = CreateObject("Msxml2.DOMDocument") Set oCmd = CreateObject("ADODB.Command") oCmd.ActiveConnection = "Provider=SQLOLEDB;Data Source=myserver;Initial Catalog=mydb;UID=me;Password=mypassword" sSQL = "<ROOT xmlns:sql='urn:schemas-microsoft-com:xml-sql'><sql:query>" &_ "exec spu_condocerts_assoc 'XML' </sql:query></ROOT>" oCmd.CommandText = sSQL oCmd.Dialect = "{5D531CB2-E6Ed-11D2-B252-00C04F681B71}" oCmd.Properties("Output Stream") = oDom oCmd.Execute , , 1024 oDom.Save "c:\savedfilename.xml" Main = DTSTaskExecResult_Success End Function Нужно в Билдэровском варианте. я тут попробовал/бую: oleobject oCmd, oDom string sSQL int i_rc oCmd = CREATE oleobject oDom = CREATE oleobject i_rc = oDom.ConnectToNewObject('Msxml2.DOMDocument') i_rc = oCmd.ConnectToNewObject('ADODB.Command') oCmd.ActiveConnection = "Provider=SQLOLEDB;Data Source=myserver;Initial Catalog=mydb;UID=me;Password=mypassword" sSQL = "<ROOT xmlns:sql='urn:schemas-microsoft-com:xml-sql'><sql:query>exec spu_condocerts_export_xml </sql:query></ROOT>" oCmd.CommandText = sSQL oCmd.Dialect = '{5D531CB2-E6Ed-11D2-B252-00C04F681B71}' oDom = oCmd.Properties('Output Stream') oCmd.Execute() oDom.Save('C:\testdts.xml') oCmd.disconnectObject() oDom.disconnectObject() DESTROY oCmd DESTROY oDom чегой то не фурычит, execute и save захлёбываютса. Туды её в качель... ... |
| 06.01.2005, 22:08:49 |
start [/forum/search_topic.php?author=Alex+R&author_mode=last_topics&do_search=1]: |
59ms |
37ms |
| others: | 435ms |
| total: | 601ms |
