Изменение свойства "Width of DropDown" в DDDW.
Как изменить свойство "Width of DropDown" в DDDW? Надо сделать что-то в таком роде: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. Код: plaintext ... |
| 03.04.2005, 14:04:29 |
File->New->Tool->Datawindow Syntax->Object:Column <DW Control Name>.Modify("<Columnname> .DDDW.PercentWidth =<100 is default. Determines width of dddw as compared to column (i.e., 300 would make the dddw 3 times wider than its column>") ... |
| 03.04.2005, 15:24:19 |
ЗоринАндрейFile->New->Tool->Datawindow Syntax->Object:Column <DW Control Name>.Modify("<Columnname> .DDDW.PercentWidth =<100 is default. Determines width of dddw as compared to column (i.e., 300 would make the dddw 3 times wider than its column>") Thanx! ... |
| 03.04.2005, 17:50:43 |
start [/forum/topic.php?fid=15&gotonew=1&tid=1338441]: |
83ms |
52ms |
| others: | 242ms |
| total: | 436ms |
