CLOB (Oracle)
Подскажиете, плиз, как в Power Builder в поле CLOB (Oracle)вставить текстовый файл? ... |
| 19.09.2005, 16:05:10 |
CLOB (Oracle)
Examples for UPDATEBLOB SQL statementThese statements update the blob column emp_pic in the Employee table where emp_num is 100: int fh blob Emp_id_pic fh = FileOpen("c:\emp_100.bmp", StreamMode!) IF fh <> -1 THEN FileRead(fh, emp_id_pic) FileClose(fh) UPDATEBLOB Employee SET emp_pic = :Emp_id_pic WHERE Emp_num = 100 USING Emp_tran ; END IF IF Emptran.SQLNRows > 0 THEN COMMIT USING Emp_tran ; END IF The blob Emp_id_pic requires a colon to indicate it is a host (PowerScript) variable in the UPDATEBLOB statement. ... |
| 19.09.2005, 16:25:21 |
start [/forum/topic.php?fid=15&gotonew=1&tid=1338130]: |
52ms |
45ms |
| others: | 224ms |
| total: | 361ms |
