PB Select TOp 50 Rows
Вот проблема: задача состоит в том чтобы Select top 50 rows, с наибольшим qty_received. Вот что я имею, so far: SELECT purchase_order.Id, purchase_order.type_Sym, purchase_order.oid, purchase_order.category_Sym, purchase_order.Description, purchase_order.Created_Date, purchase_order.Status_Sym, purchase_order.Status_Date, purchase_order.Due_Date, purchase_order_data.serial_number, Item_Master.id, Item_Master.description, purchase_order_Data.qty_received, /*'qty' = (select sum(purchase_order_data.qty_received) from purchase_order_data where po_oid = purchase_order.oid ), */'date' = Dateadd(month, -12, getutcdate()) FROM purchase_order , purchase_order_data, Item_Master WHERE ( purchase_order_data.PO_oid = purchase_order.oid ) and ( purchase_order_data.Item_Oid = Item_Master.oid ) and purchase_order.Created_Date >= Dateadd(month, -12, getutcdate()) and purchase_order.status_sym = 'closed' I grouped per Item_Master.id and sum the qty_received in DW. It won't let me sort by the Compute field and I need to display only top 50 ( largetst qty_received rows. Огромное спасибо всем за помоSELECT purchase_order.Id, purchase_order.type_Sym, purchase_order.oid, purchase_order.category_Sym, purchase_order.Description, purchase_order.Created_Date, purchase_order.Status_Sym, purchase_order.Status_Date, purchase_order.Due_Date, purchase_order_data.serial_number, Item_Master.id, Item_Master.description, purchase_order_Data.qty_received, /*'qty' = (select sum(purchase_order_data.qty_received) from purchase_order_data where po_oid = purchase_order.oid ), */'date' = Dateadd(month, -12, getutcdate()) FROM purchase_order , purchase_order_data, Item_Master WHERE ( purchase_order_data.PO_oid = purchase_order.oid ) and ( purchase_order_data.Item_Oid = Item_Master.oid ) and purchase_order.Created_Date >= Dateadd(month, -12, getutcdate()) and purchase_order.status_sym = 'closed' Спасибо за помощь всем ... |
| 23.03.2006, 19:42:33 |
start [/forum/topic.php?fid=15&gotonew=1&tid=1337864]: |
47ms |
| others: | 200ms |
| total: | 304ms |
