Database Update
я что-то пропускаю ?, данные не сохраняются : Integer ls_employee_oid String ls_dl_no, ls_dl_state, ls_dl_issued_date, ls_dl_expired_date, ls_dl_lens ls_employee_oid = dw_1.getItemNumber(1, 'employee_oid') ls_dl_no = sle_1.text ls_dl_state = sle_2.text ls_dl_lens = sle_3.text ls_dl_issued_date = em_1.text ls_dl_expired_date = em_2.text UPDATE employee_data set Driver_License_no = :ls_dl_no, Driver_license_State = :ls_dl_state, Driver_license_Issued_date = :ls_dl_issued_date, Driver_license_Expired_date = :ls_dl_expired_date, Driver_license_Lens = :ls_dl_lens where oid = :ls_employee_oid; MessageBox("Save","Database has been updated.") ... |
| 27.07.2006, 18:12:35 |
Database Update
PowerBuilder Help Error handling It is good practice to test the success/failure code after executing a UPDATE statement. You can test SQLCode for a failure code. However, if nothing matches the WHERE clause and no rows are updated, SQLCode is still set to zero. To make sure the update affected at least one row, check the SQLNRows property of the transaction object. ... |
| 27.07.2006, 18:16:06 |
Database Update
сommit забыла --- http://www.rusug.ru] Портал рускоязычной группы пользователей Sybase ... |
| 27.07.2006, 18:16:08 |
Database Update
чото в духе: if sqlca.sqlcode <> 0 then commit; else rollback; end if написать бы ... |
| 27.07.2006, 18:25:54 |
Database Update
spasibo ogromnoe, no v if sqlca.sqlcode <> 0 then commit; else rollback; end if Commit ne prohodit, but bez error check it worked.??? ... |
| 27.07.2006, 18:50:25 |
Database Update
думаю твоя проблема уже решена. вопрос к тебе, а почему ты не используеш datawindow's для update? ... |
| 27.07.2006, 18:51:07 |
Database Update
then ia dolzhna pass all the argumets to datawidow?. I think its easier this way ( skaxhite esli ia ne prava). ... |
| 27.07.2006, 19:01:51 |
Database Update
SvetaShthen ia dolzhna pass all the argumets to datawidow?. I think its easier this way ( skaxhite esli ia ne prava).Вы неправы, прежде всего, создавая дизайн пользовательского интерфейса, который не использует DW. Почему Вы не используете для ввода данных DW, построенное на запросе вида Код: plaintext 1. 2. 3. 4. 5. 6. 7. Применяя подход, рекомендуемый средой разработки, Ваш код сводится примерно к следующему: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. SvetaShCommit ne prohoditНичего не понял, поясните ... |
| 27.07.2006, 19:49:47 |
Database Update
SvetaShspasibo ogromnoe, no v if sqlca.sqlcode <> 0 then commit; else rollback; end if Commit ne prohodit, but bez error check it worked.??? Это неверный код, надо так: Код: plaintext 1. 2. 3. 4. 5. ... |
| 27.07.2006, 19:52:57 |
Database Update
PL99Ничего не понял, поясните Anatoly Moskovsky SvetaShspasibo ogromnoe, no v if sqlca.sqlcode <> 0 then commit; else rollback; end if Commit ne prohodit, but bez error check it worked.??? Это неверный код, надо так: Код: plaintext 1. 2. 3. 4. 5. ... |
| 27.07.2006, 19:56:05 |
Database Update
Света, проостите за нескромный вопрос, а где вы живете и работаете ... |
| 27.07.2006, 20:21:10 |
Database Update
Kakoe это имеет отношение к моему вопросу. Когда-то жила и училась в Москве, сеичас живу и работаю в US. Если вас смущает мой вопрос, как говорится ( у вас) "я не Волшебник, я только учусь".... ... |
| 27.07.2006, 21:36:00 |
Database Update
SvetaSh wrote: > Если вас смущает мой вопрос Раздражает незнание элементарных вещей и каша из русского и английского. Posted via ActualForum NNTP Server 1.3 ... |
| 28.07.2006, 10:00:07 |
Database Update
Dim2000 SvetaSh wrote: > Если вас смущает мой вопрос Раздражает незнание элементарных вещей и каша из русского и английского. Posted via ActualForum NNTP Server 1.3 Раздражает,не читаите, ни кто вас к этому не принуждает. А вообще если такой раздражительный, seek professional help. ... |
| 28.07.2006, 16:17:47 |
Database Update
To SvetaSh Девочка, мало того, что у тебя вся логика на клиенте, что само по себе плохо! Ты к тому же и не ведаешь по-моему, что творишь! А грубить тебе рановато, ибо ты в профессиональном плане новичок! ... |
| 28.07.2006, 16:32:44 |
Database Update
SvetaSh Раздражает,не читаите, ни кто вас к этому не принуждает. А вообще если такой раздражительный, seek professional help. А хамить зачем? ... |
| 28.07.2006, 18:02:15 |
Database Update
да, чото я там маху дал ... |
| 28.07.2006, 18:08:09 |
Database Update
Света не обижайтесь, просто ... Как-бы это сказать Немного смешной акцент А вообще мы парни не злобивые......... ... |
| 29.07.2006, 15:26:21 |
start [/forum/topic.php?fid=15&gotonew=1&tid=1337669]: |
46ms |
56ms |
| others: | 229ms |
| total: | 381ms |
