Требуется executable
Требуется executable. Если кто-то может помочь создать его, я буду очень благодарна. Есть flightboard, которая generated with executable. Мне нужно создать такую же, предварительно сделав маленькие поправки, и не трогая оригинала, сделать еще одну flightboard. я, к сожалению не имею понятия как create executable. Please, help. Большое спасибо, заранее. Света ... |
| 27.11.2006, 18:26:58 |
Света, пожалуйста поподробнее Можешь на английском ... |
| 27.11.2006, 19:41:55 |
Может ей лучше Help на английском почитать? ... |
| 27.11.2006, 19:44:50 |
I have an existing flight board, that's displayed on the projector for the Dispatch department. Dispatcher can see the board on his desctop , if he modifies it its modified on the projector too. What I need is to create another ( copy) flight board that they will be able to see on their desctop and will be able to modify without modifying the projected one. thanks a lot to those who are trying to help ( and ne tem kto meshaet rabotat', ia tak ponimau you know who you are). ... |
| 27.11.2006, 19:59:18 |
"displayed on the projector for the Dispatch department" ??? Projector is just another display. Usualy it is just a copy of main display and shows the same picture you see on your desktop. Sometimes you can setup projector to work as secondary display and in that case you can have different pictures on your desktop and projector. But this is a hardware problem, it has nothing to do with executable or PowerBuilder. Go to your technichian and ask him to setup two displays on your workstation. Then you learn how to work with different displays configuration. Then you can replays one of your display with projector. --- http://www.rusug.ru] Портал русскоязычной группы пользователей Sybase ... |
| 27.11.2006, 20:23:52 |
da no, esli ia meniau display on the desctop, database meniaetsia i display on the projector meniaestsia tozhe. ex. Ia mogu vibrat' aircrafts to display on the flightboard. Eto delaetsia pri pomoszhi column v aicraft_data tablitse. if the flight_board_display column true to aircraft displayed if false, doesn't. Projected display chitaet s toi zhe database, tak chto esli ia meniau display on the destop, projected display meniaetsia tozhe. ... |
| 27.11.2006, 21:33:11 |
Мдя, по русски говорить не умеет, по английски тоже не понимает. --- http://www.rusug.ru] Портал русскоязычной группы пользователей Sybase ... |
| 27.11.2006, 22:18:24 |
Уже в который раз убеждаюсь, что этот форум пустая трата времени, Жаль, что проходится общаться с такими не культурными и не воспитанными людьми. я так полагаю, что форум создан для того чтоб помочь друг другу, но какой помощи можно ждать он Русского народа. Кстати, нет ни одной нации в мире которая если ты падаешь вместо того чтобы подать руку, подтолкнет еще.. Очень жаль что жизнь вас так и не научила... Спасибо за "помощь". ... |
| 28.11.2006, 00:40:33 |
Здорово. Плохому танцору известно что мешает, а вот плохой танцорке - оказывается Русский народ , надо же... ... |
| 28.11.2006, 01:10:59 |
SvetaShУже в который раз убеждаюсь, что этот форум пустая трата времени, Жаль, что проходится общаться с такими не культурными и не воспитанными людьми. я так полагаю, что форум создан для того чтоб помочь друг другу, но какой помощи можно ждать он Русского народа. Кстати, нет ни одной нации в мире которая если ты падаешь вместо того чтобы подать руку, подтолкнет еще.. Очень жаль что жизнь вас так и не научила... Спасибо за "помощь". Света, вы зря обижаетесь. Вы невозможно плохо формулируете описание проблем, описывая ситуацию из своей предметной области, очевидно рассчитывая, что все в этом форуме знакомы с системами учета полетов (или как они у вас называются) с которыми вы работаете. Вы не делаете даже попытки абстрагироваться от своей конкретики и описывать ситуацию и объекты PB общими словами (окно, транзакция, приложение и т.п.), а потом говорите что "русский народ" плохой. Многие в этом форуме искренне хотели бы вам помочь, но по причине вышесказанного это практически невозможно. ... |
| 28.11.2006, 06:51:27 |
Света - это форум по вопросам программирования Спрашивают здесь конкретные вопросы о конкретных вещах Иначе надо обращаться на форум программистов - авиадиспетчеров ... |
| 28.11.2006, 09:17:06 |
Обычно нахожусь в режиме ReadOnly , но это способно поднять даже мертвого: SvetaShЖаль, что проходится общаться с такими не культурными и не воспитанными людьми. я так полагаю, что форум создан для того чтоб помочь друг другу, но какой помощи можно ждать он Русского народа. Кстати, нет ни одной нации в мире которая если ты падаешь вместо того чтобы подать руку, подтолкнет еще.. Очень жаль что жизнь вас так и не научила... Да-а. Такого хамла я еще не видел на форуме... Полностью согласен с AndynВы невозможно плохо формулируете описание проблем Тем не менее, из прочитанного мной и основываясь на: SvetaShМне нужно создать такую же, предварительно сделав маленькие поправки, и не трогая оригинала SvetaShDispatcher can see the board on his desctop , if he modifies it its modified on the projector too. What I need is to create another ( copy) flight board that they will be able to see on their desctop and will be able to modify without modifying the projected one 1. Может быть, SvetaSh хочет подправить уже существующий проект. Тогда надо смотреть здесь 2. Можно сделать вывод, что при выборе какой-то хрени диспетчером на его компе показания программы на каком-то особом экране не должны измениться. Смею предположить, что дело происходит с DataWindow , т.е. подобные вещи делаются, используя специальный column . Если его значение равно 1, то другое поле будет видимым, если = 0, то нужное поле становится invisible, плюс некий признак, что информация отображается на специальном экране . Данный признак говорит о том, что нужно скрывать некие действия пользователя на другом компьютере и обновление данных, в данном случае, должно происходить по таймеру. Что и как взаимосвязано - на совести программиста. P.S.: Был бы я модератором, то вынес бы г-же SvetaSh предупреждение на первый раз, на второй просто бы забанел... ... |
| 28.11.2006, 11:26:35 |
Конечно, женщинам позволено многое, но ... это слишком. Да, на форуме в основном мужики. Да, иногда хамят друг другу. Иногда. Но, почти всегда, готовы помочь. Но не позволительно, плевать на весь народ. На любой народ. Это нацизм. Тем более, что она знает о русском народе, это Света, с промытыми мозгами ? Мир велик. Пусть ищет лучших. SvetaSh - go out ! Good Luck ! ... |
| 29.11.2006, 09:58:10 |
start [/forum/topic.php?fid=15&gotonew=1&tid=1337435]: |
33ms |
69ms |
| others: | 235ms |
| total: | 389ms |
