syntax data window
Data window ‘Grid’ - печать Код: plaintext 1. 2. 3. ... |
| 05.07.2007, 11:45:15 |
syntax data window
Description The way grid lines display and print in a DataWindow whose presentation style is Grid or Crosstab. Controls DataWindows Syntax Dot notation: dw_control.Object.DataWindow.Grid.Lines Describe and Modify argument: "DataWindow.Grid.Lines { = value}" Parameter Description value An integer specifying whether grid lines are displayed on the screen and printed. Values are:0 — Yes, grid lines are displayed and printed1 — No, grid lines are not displayed and printed2 — Grid lines are displayed, but not printed3 — Grid lines are printed, but not displayed Usage In the painter Set the value using the DataWindow Object property sheet, General tab, Grid group, Display option (available when the presentation style is Grid or Crosstab). ... |
| 05.07.2007, 12:26:27 |
syntax data window
urvas БОЛЬШОЕ СПАСИБО, УДАЛОСЬ, ПРАВДА САМОМУ НАЙТИ ТО ЖЕ САМОЕ, ВСЁ ОК! Но вопрос был послан, прошу прощения за отобранное у Вас время. Ещё раз СПАСИБО ... |
| 06.07.2007, 11:50:46 |
start [/forum/topic.php?fid=15&gotonew=1&tid=1337083]: |
53ms |
38ms |
| others: | 196ms |
| total: | 327ms |
