ПРОВЕРКА КОРРЕКТНОСТИ ВВЕДЕННЫХ ДАННЫХ в DATA WINDOW
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. ... |
| 20.03.2008, 18:05:03 |
ItemChanged может вернуть код завершения который влияет на дальнейшее поведение DataWindow. Вам наверное нужен 2? ... |
| 20.03.2008, 18:12:23 |
... или 1, нужно посмотреть... ... |
| 20.03.2008, 18:14:26 |
event ItemChanged() DataWindows Return value Set the return code to affect the outcome of the event: 0 (Default) Accept the data value 1 Reject the data value and do not allow focus to change 2 Reject the data value but allow the focus to change For information on setting the return code in a particular environment, see "About return values for DataWindow events". and view event itemerror() DataWindow Return value Set the return code to affect the outcome of the event: 0 (Default) Reject the data value and show an error message box 1 Reject the data value with no message box 2 Accept the data value 3 Reject the data value but allow focus to change For information on setting the return code in a particular environment, see "About return values for DataWindow events". ... |
| 20.03.2008, 20:11:58 |
start [/forum/topic.php?fid=15&gotonew=1&tid=1336738]: |
43ms |
42ms |
| others: | 211ms |
| total: | 345ms |
