foreground
подскажите как установить foreground для объекта в DW команда dw_1.modify("client_t.band=foreground") не работает спасибо ... |
| 21.08.2008, 15:53 |
foreground
Оно? SetPosition PowerScript function: Syntax 2 For positioning objects within a DataWindow Description Moves an object within the DataWindow to another band or changes the front-to-back order of objects within a band. Controls DataWindow controls and DataStores Syntax dwcontrol.SetPosition ( objectname, band, bringtofront ) Argument Description dwcontrol The name of the DataWindow control or DataStore containing the object. objectname The name of the object within the DataWindow that you want to move. You assign names to the DataWindow objects in the DataWindow painter. band The name of the band or layer in which you want to position objectname.Layer names are background and foreground.Band names are detail, header, footer, summary, header.#, and trailer.#.# is the group level number. Enter the empty string ("") if you do not want to change the band bringtofront A boolean indicating whether you want to bring objectname to the front within the band:· TRUE - Bring it to the front· FALSE - Do not bring it to the front Return value Integer. Returns 1 when it succeeds and -1 if an error occurs. If any argument's value is null, SetPosition returns null. ... |
| 21.08.2008, 16:13 |
start [/forum/topic.php?fid=15&gotonew=1&tid=1336558]: |
54ms |
50ms |
| others: | 195ms |
| total: | 355ms |
