xml-(xslt)->xml
День добрый, есть ли встроенное усечение строк, отличное от приведенного ниже? Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. ... |
| 15.03.2006, 17:39:47 |
xml-(xslt)->xml
КритикДень добрый, есть ли встроенное усечение строк, отличное от приведенного ниже?.... Код: plaintext 1. 2. Example The following example normalizes a block of text string with unnormalized white spaces (tabs, leading and trailing spaces, and multiple spaces between words. The text string is the value of an <text> element. XML File (normSpace.xml) <?xml version="1.0"?> <?xml-stylesheet type="text/xsl" href="normalizeSpace.xsl"?> <text> This is a test, with a lot of irregular spacing and waiting to be normalizaed. </text> XSLT File (normSpace.xsl) <?xml version='1.0'?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"> <xsl:output method="xml" omit-xml-declaration="yes"/> <xsl:template match="/text"> Unnormalized: "<xsl:value-of select='.'/>" Normalized: "<xsl:value-of select='normalize-space()'/>" </xsl:template> </xsl:stylesheet> This XSLT produces the following output: Unormalized: " This is a test, with a lot of irregular spacing and waiting to be normalizaed. " Normalized: "This is a test, with a lot of irregular spacing and waiting to be normalized." ... |
| 16.03.2006, 10:38:45 |
start [/forum/topic.php?fid=14&gotonew=1&tid=1334849]: |
177ms |
31ms |
| others: | 227ms |
| total: | 468ms |
