xsl functions extensions
Привет. Подскажите пожалуйста, какой namespace указать? test.xml ------------------------------------------------------------------------ <?xml version="1.0" encoding="UTF-8"?> <?xml-stylesheet type="text/xsl" href="test.xsl"?> <entries gameID="DWO"> <entry> <player>John</player> <guess>3</guess> <guess>9</guess> <guess>222</guess> </entry> <entry> <player>Mary</player> <guess>88</guess> <guess>76</guess> <guess>5</guess> </entry> </entries> ------------------------------------------------------------------------ test.xsl ------------------------------------------------------------------------ <?xml version="1.0"?> <xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:lxslt="http://xml.apache.org/xslt" xmlns:myext="myext" extension-element-prefixes="myext" version="1.0"> <lxslt:component prefix="myext" elements="rules" functions="getResult"> <lxslt:script lang="javascript"> function getResult (thisGuess) { var thisResult = parseInt(Math.random()*100); if (thisResult == parseInt(thisGuess)) { return "Correct!"; } else { return "Wrong! The actual answer was "+thisResult+ ", not "+thisGuess+"."; } } </lxslt:script> </lxslt:component> <xsl:template match="/"> <xsl:apply-templates/> </xsl:template> <xsl:template match="entry"> Guesser: <xsl:value-of select="player"/> <xsl:apply-templates select="guess"/> </xsl:template> <xsl:template match="guess"> Guess: <xsl:value-of select="."/> Actual: <xsl:value-of select="myext:getResult(string(.))"/> </xsl:template> </xsl:stylesheet> ------------------------------------------------------------------------ При просмотре test.xml в IE 6.0 вылезает следующее Guesser: John Guess: 3 Actual: The XML page cannot be displayed Cannot view XML input using XSL style sheet. Please correct the error and then click the Refresh button, or try again later. -------------------------------------------------------------------------------- Namespace 'myext' does not contain any functions. Заранее спасибо за любую помощь ... |
| 07.11.2006, 18:49 |
ты уверен, что msxml это поддерживает? ... |
| 08.11.2006, 12:57 |
Sorry, действительно здесь нужен Apache Project's Xalan Java 2. Не подскажите, а с помощью msxml что-то подобное можно сделать (например: <xsl:variable name = "myvar" select="значение возвращаемое js"/>) Спасибо ... |
| 08.11.2006, 17:35 |
start [/forum/search_topic.php?author=%D0%93%D0%BE%D0%BB%D0%B8%D0%BA%D0%BE%D0%B2&author_mode=last_topics&do_search=1]: |
172ms |
44ms |
| others: | 9550ms |
| total: | 9963ms |
