Как сделать вложенный тег
Помогите пожалуйста!!! У меня есть xml : <?xml version="1.0"?> <ediroot> <interchange Standard="EDIFACT" Date="070313" Time="1432" Control="000114696"> <sender> <address Id="GVCMPSRU" Qual=""/> </sender> <receiver> <address Id="GIVCUZ" Qual=""/> </receiver> <group> <transaction Control="03131411005167" DocType="IFTMIN"> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">11111111</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720359130</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720373140</element> <element Id="SEL02">CA</element> </segment> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">22222222</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">33333333</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="SEL"> <element Id="SEL01">0033333311</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">0033333322</element> <element Id="SEL02">CA</element> </segment> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">44444444</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">55555555</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="SEL"> <element Id="SEL01">0055555511</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">0055555522</element> <element Id="SEL02">CA</element> </segment> </transaction> </group> </interchange> </ediroot> У меня есть xsl : <?xml version="1.0"?> <xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0"> <xsl:output method="xml" encoding="windows-1251" indent="yes"/> <xsl:template match="/ediroot/interchange"> <UZ-XDOC doc_version="1.0" doc_type="data"> <HEAD from="{sender/address/@Id}" to="{receiver/address/@Id}" messcode="2514"/> <BODY> <xsl:apply-templates select="group/transaction"/> </BODY> </UZ-XDOC> </xsl:template> <xsl:template match="transaction"> <xsl:element name="OTPR"> <xsl:apply-templates select="segment[@Id='EQD' and element[@Id='EQD01']='RR']"/> </xsl:element> </xsl:template> <xsl:template match="segment[@Id='EQD' and element[@Id='EQD01']='RR']"> <xsl:element name="VAGON"> <xsl:attribute name="nom_pp"> <xsl:number value="position()" format="1"/> </xsl:attribute> <xsl:apply-templates select="following-sibling::segment[@Id='SEL']"/> </xsl:element> </xsl:template> <xsl:template match="segment[@Id='SEL']"> <xsl:if test="element[@Id='SEL01']"> <xsl:variable name="dt" select="element[@Id='SEL01']"/> <xsl:element name="PAY"> <xsl:attribute name="date_op"> <xsl:value-of select="substring($dt,3,8)"/> </xsl:attribute> </xsl:element> </xsl:if> </xsl:template> </xsl:stylesheet> После преобразования получается: <?xml version="1.0" encoding="windows-1251"?> <UZ-XDOC doc_version="1.0" doc_type="data"> <HEAD from="GVCMPSRU" to="GIVCUZ" messcode="2514" /> <BODY> <OTPR> <VAGON nom_pp="1"> <PAY date_op="20359130" /> <PAY date_op="20373140" /> <PAY date_op="33333311" /> <PAY date_op="33333322" /> <PAY date_op="55555511" /> <PAY date_op="55555522" /> </VAGON> <VAGON nom_pp="2"> <PAY date_op="33333311" /> <PAY date_op="33333322" /> <PAY date_op="55555511" /> <PAY date_op="55555522" /> </VAGON> <VAGON nom_pp="3"> <PAY date_op="33333311" /> <PAY date_op="33333322" /> <PAY date_op="55555511" /> <PAY date_op="55555522" /> </VAGON> <VAGON nom_pp="4"> <PAY date_op="55555511" /> <PAY date_op="55555522" /> </VAGON> <VAGON nom_pp="5"> <PAY date_op="55555511" /> <PAY date_op="55555522" /> </VAGON> </OTPR> </BODY> </UZ-XDOC> А должно получиться: <?xml version="1.0" encoding="windows-1251"?> <UZ-XDOC doc_version="1.0" doc_type="data"> <HEAD from="GVCMPSRU" to="GIVCUZ" messcode="2514" /> <BODY> <OTPR> <VAGON nom_pp="1"> <PAY date_op="20359130" /> <PAY date_op="20373140" /> </VAGON> <VAGON nom_pp="2"> </VAGON> <VAGON nom_pp="3"> <PAY date_op="33333311" /> <PAY date_op="33333322" /> </VAGON> <VAGON nom_pp="4"> </VAGON> <VAGON nom_pp="5"> <PAY date_op="55555511" /> <PAY date_op="55555522" /> </VAGON> </OTPR> </BODY> </UZ-XDOC> ... |
| 21.03.2007, 16:06:45 |
Код: plaintext 1. ... |
| 21.03.2007, 18:38:22 |
спасибо огромное, но если в начальный XML добалляются ещё теги(между <segment Id="EQD"> и <segment Id="SEL">), то всёравно не получается. На пример <?xml version="1.0"?> <ediroot> <interchange Standard="EDIFACT" Date="070313" Time="1432" Control="000114696"> <sender> <address Id="GVCMPSRU" Qual=""/> </sender> <receiver> <address Id="GIVCUZ" Qual=""/> </receiver> <group> <transaction Control="03131411005167" DocType="IFTMIN"> <segment Id="BGM"> <element Id="BGM01">720</element> <element Id="BGM02">AA949489</element> <element Id="BGM03">9</element> </segment> <segment Id="DTM"> <element Id="DTM01" Composite="yes"> <subelement Id="DTM01" Composite="yes" Sequence="1">143</subelement> <subelement Sequence="2">200703131357</subelement> <subelement Sequence="3">203</subelement> </element> </segment> <segment Id="TSR"> <element Id="TSR02" Composite="yes"> <subelement Id="TSR02" Composite="yes" Sequence="1">4</subelement> <subelement Sequence="4">2</subelement> </element> <element Id="TSR03">3</element> </segment> <segment Id="FTX"> <element Id="FTX01">DCL</element> <element Id="FTX04" Composite="yes"> <subelement Id="FTX04" Composite="yes" Sequence="1">OПЛATA ПO PЖД ЗAKPЫTOE AKЦИOHEPHOE OБЩECTBO " HEФTETPAHCПOPT" 6643512</subelement> <subelement Sequence="2">ЧEPEЗ HФ</subelement> </element> </segment> <segment Id="FTX"> <element Id="FTX01">RQR</element> <element Id="FTX04">20439701</element> <element Id="FTX05">RUS</element> </segment> <segment Id="GOR"> <element Id="GOR01">1</element> <element Id="GOR02">5</element> </segment> <segment Id="TDT"> <element Id="TDT01">21</element> <element Id="TDT03">2</element> </segment> <segment Id="LOC"> <element Id="LOC01">5</element> <element Id="LOC02" Composite="yes"> <subelement Id="LOC02" Composite="yes" Sequence="1">20653003</subelement> <subelement Sequence="2">37</subelement> <subelement Sequence="3">288</subelement> <subelement Sequence="4">CAЛABAT</subelement> </element> </segment> <segment Id="LOC"> <element Id="LOC01">8</element> <element Id="LOC02" Composite="yes"> <subelement Id="LOC02" Composite="yes" Sequence="1">22403002</subelement> <subelement Sequence="2">37</subelement> <subelement Sequence="3">288</subelement> <subelement Sequence="4">ХИМИЧЕСКАЯ-ЭКСПОРТ</subelement> </element> </segment> <segment Id="LOC"> <element Id="LOC01">17</element> <element Id="LOC02" Composite="yes"> <subelement Id="LOC02" Composite="yes" Sequence="1">20439701</subelement> <subelement Sequence="2">37</subelement> <subelement Sequence="3">288</subelement> <subelement Sequence="4">COЛOBEЙ_ ЭKCП_</subelement> </element> </segment> <segment Id="NAD"> <element Id="NAD01">CN</element> <element Id="NAD02" Composite="yes"> <subelement Id="NAD02" Composite="yes" Sequence="1">1070</subelement> <subelement Sequence="2">100</subelement> </element> <element Id="NAD04">OOO "TPAHCИHBECTCEPBИC"</element> <element Id="NAD05">УKPAИHA</element> <element Id="NAD09">TR</element> </segment> <segment Id="NAD"> <element Id="NAD01">CZ</element> <element Id="NAD02" Composite="yes"> <subelement Id="NAD02" Composite="yes" Sequence="1">2505</subelement> <subelement Sequence="2">100</subelement> </element> <element Id="NAD04" Composite="yes"> <subelement Id="NAD04" Composite="yes" Sequence="1">OTKPЫTOE AKЦИOHEPHOE OБЩECTBO "CAЛA</subelement> <subelement Sequence="2">BATHEФTEOPГCИHTEЗ"</subelement> </element> <element Id="NAD05" Composite="yes"> <subelement Id="NAD05" Composite="yes" Sequence="1">453256 CAЛABAT MOЛOДOГBAPДEЙЦEB -</subelement> <subelement Sequence="2">30</subelement> </element> <element Id="NAD08">453256</element> <element Id="NAD09">RU</element> </segment> <segment Id="GID"> <element Id="GID01">1</element> <element Id="GID02" Composite="yes"> <subelement Sequence="2">02</subelement> <subelement Sequence="5">Насыпью, твердые гранулированные ча</subelement> </element> </segment> <segment Id="LOC"> <element Id="LOC01">27</element> <element Id="LOC02" Composite="yes"> <subelement Id="LOC02" Composite="yes" Sequence="1">RU</subelement> <subelement Sequence="2">162</subelement> <subelement Sequence="3">5</subelement> </element> </segment> <segment Id="LOC"> <element Id="LOC01">28</element> <element Id="LOC02" Composite="yes"> <subelement Id="LOC02" Composite="yes" Sequence="1">TR</subelement> <subelement Sequence="2">162</subelement> <subelement Sequence="3">5</subelement> </element> </segment> <segment Id="LOC"> <element Id="LOC01">35</element> <element Id="LOC02" Composite="yes"> <subelement Id="LOC02" Composite="yes" Sequence="1">RU</subelement> <subelement Sequence="2">162</subelement> <subelement Sequence="3">5</subelement> </element> </segment> <segment Id="PIA"> <element Id="PIA01">5</element> <element Id="PIA02" Composite="yes"> <subelement Id="PIA02" Composite="yes" Sequence="1">31021090</subelement> <subelement Sequence="2">HS</subelement> <subelement Sequence="4">12</subelement> </element> </segment> <segment Id="FTX"> <element Id="FTX01">AAA</element> <element Id="FTX04">MOЧEBИHA ПPOЧAЯ</element> </segment> <segment Id="FTX"> <element Id="FTX01">IRP</element> <element Id="FTX04">15</element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">G</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">317850</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">ASW</element> <element Id="MEA02">G</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">423300</subelement> </element> </segment> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">11111111</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="MEA"> <element Id="MEA01">SV</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">TNE</subelement> <subelement Sequence="2">70</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">NAX</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">PCE</subelement> <subelement Sequence="2">4</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">ASW</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">20800</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">22000</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">AAD</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">64800</subelement> </element> </segment> <segment Id="SEL"> <element Id="SEL01">1720359940</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720373740</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720373741</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720373742</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720373743</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720373744</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720373745</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720373746</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720373747</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720368901</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720368902</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720368903</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720368904</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720368905</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720368906</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720368907</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">1720368908</element> <element Id="SEL02">CA</element> </segment> <segment Id="NAD"> <element Id="NAD01">CW</element> <element Id="NAD02" Composite="yes"> <subelement Id="NAD02" Composite="yes" Sequence="1">20/1</subelement> <subelement Sequence="2">36</subelement> <subelement Sequence="3">12</subelement> </element> </segment> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">22222222</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="MEA"> <element Id="MEA01">SV</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">TNE</subelement> <subelement Sequence="2">65</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">NAX</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">PCE</subelement> <subelement Sequence="2">4</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">ASW</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">21500</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">21500</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">AAD</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">64650</subelement> </element> </segment> <segment Id="NAD"> <element Id="NAD01">CW</element> <element Id="NAD02" Composite="yes"> <subelement Id="NAD02" Composite="yes" Sequence="1">20/1</subelement> <subelement Sequence="2">36</subelement> <subelement Sequence="3">12</subelement> </element> </segment> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">33333333</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="MEA"> <element Id="MEA01">SV</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">TNE</subelement> <subelement Sequence="2">70</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">NAX</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">PCE</subelement> <subelement Sequence="2">4</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">ASW</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">20800</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">22000</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">AAD</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">64800</subelement> </element> </segment> <segment Id="SEL"> <element Id="SEL01">0020359901</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">0020373702</element> <element Id="SEL02">CA</element> </segment> <segment Id="SEL"> <element Id="SEL01">0020373703</element> <element Id="SEL02">CA</element> </segment> <segment Id="NAD"> <element Id="NAD01">CW</element> <element Id="NAD02" Composite="yes"> <subelement Id="NAD02" Composite="yes" Sequence="1">20/1</subelement> <subelement Sequence="2">36</subelement> <subelement Sequence="3">12</subelement> </element> </segment> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">90250259</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="MEA"> <element Id="MEA01">SV</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">TNE</subelement> <subelement Sequence="2">65</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">NAX</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">PCE</subelement> <subelement Sequence="2">4</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">ASW</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">20600</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">22000</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">AAD</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">64600</subelement> </element> </segment> <segment Id="NAD"> <element Id="NAD01">CW</element> <element Id="NAD02" Composite="yes"> <subelement Id="NAD02" Composite="yes" Sequence="1">20/1</subelement> <subelement Sequence="2">36</subelement> <subelement Sequence="3">12</subelement> </element> </segment> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">90273772</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="MEA"> <element Id="MEA01">SV</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">TNE</subelement> <subelement Sequence="2">70</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">NAX</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">PCE</subelement> <subelement Sequence="2">4</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">ASW</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">20400</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">22000</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">AAD</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">66700</subelement> </element> </segment> <segment Id="NAD"> <element Id="NAD01">CW</element> <element Id="NAD02" Composite="yes"> <subelement Id="NAD02" Composite="yes" Sequence="1">20/1</subelement> <subelement Sequence="2">36</subelement> <subelement Sequence="3">12</subelement> </element> </segment> <segment Id="EQD"> <element Id="EQD01">RR</element> <element Id="EQD02">90572439</element> <element Id="EQD03">92</element> <element Id="EQD06">5</element> </segment> <segment Id="MEA"> <element Id="MEA01">SV</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">TNE</subelement> <subelement Sequence="2">70</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">NAX</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">PCE</subelement> <subelement Sequence="2">4</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">ASW</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">22300</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">T</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">23000</subelement> </element> </segment> <segment Id="MEA"> <element Id="MEA01">WT</element> <element Id="MEA02">AAD</element> <element Id="MEA03" Composite="yes"> <subelement Id="MEA03" Composite="yes" Sequence="1">KGM</subelement> <subelement Sequence="2">57100</subelement> </element> </segment> <segment Id="NAD"> <element Id="NAD01">CW</element> <element Id="NAD02" Composite="yes"> <subelement Id="NAD02" Composite="yes" Sequence="1">20/1</subelement> <subelement Sequence="2">36</subelement> <subelement Sequence="3">12</subelement> </element> </segment> </transaction> </group> </interchange> </ediroot> ... |
| 22.03.2007, 11:42:07 |
Просьба весь текст не выкладывать...этож нечитабельно!!! Сдесь на этом форуме токо один человек так выложил (и слава модератору:)). И чего? чтоб понять где ты всунул один тег придется весь документ читать? Пиши минимизированный пример, повторяющиеся места вообще можно заменить на многоточие. Первый раз я еще понимаю, ты выложил, чтоб описать картину в целом, но второй раз зачем? Тем более это бъет по трафику тех кто тебе помогает ... |
| 22.03.2007, 12:49:12 |
start [/forum/topic.php?fid=14&gotonew=1&tid=1334391]: |
70ms |
63ms |
| others: | 197ms |
| total: | 394ms |
