Ругань на строку 'Node:=XMLDoc.DocumentElement;' (Delphi7)
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. --------------------------- Debugger Fault Notification --------------------------- Project C:\Program Files\Borland\Delphi7\Projects\XMLproga\MyXML.exe raised too many consecutive exceptions:'access violation at 0x00000000: read of address 0x00000000'. Process Stopped. Use Step or Run to continue. --------------------------- OK Help --------------------------- Как быть? XML-файл: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. ... |
| 15.05.2007, 13:15:04 |
start [/forum/topic.php?fid=14&gotonew=1&tid=1334303]: |
32ms |
43ms |
| others: | 192ms |
| total: | 317ms |
