Неправильный WSDL. Проблема с minOccurs="0". HELP ME PLEASE
.net генерирует неправильный WSDL Пишу WebService (.asmx) Предположем дана структура: public struct Authors{ public int AuthorKey; public string AuthorFName; public string AuthorLName; }; генерируется WSDL: <s:complexType name="Authors"> <s:sequence> <s:element minOccurs="1" maxOccurs="1" name="AuthorKey" type="s:int" /> <s:element minOccurs=" 0 " maxOccurs="1" name="AuthorFName" type="s: string " /> <s:element minOccurs=" 0 " maxOccurs="1" name="AuthorLName" type="s: string " /> </s:sequence> </s:complexType> должно быть: <s:complexType name="Authors"> <s:sequence> <s:element minOccurs="1" maxOccurs="1" name="AuthorKey" type="s:int" /> <s:element minOccurs=" 1 " maxOccurs="1" name="AuthorFName" type="s: string " /> <s:element minOccurs=" 1 " maxOccurs="1" name="AuthorLName" type="s: string " /> </s:sequence> </s:complexType> неправильно генерирует только для типа string перепробывал все атрибуты... ничего хорошего не нашел КАК ЭТО ИСПРАВИТЬ??? ... |
| 03.10.2006, 12:34 |
если так? Код: plaintext 1. 2. 3. 4. 5. ... |
| 03.10.2006, 12:56 |
maXmoесли так? Код: plaintext 1. 2. 3. 4. 5. [XmlElement(IsNullable = true )] решение: http://www.sql.ru/forum/actualthread.aspx?tid=345422 ... |
| 03.10.2006, 12:59 |
cbqqnb A number of universities have awarded her honorary degrees, and she earned a prestigious job on the staff of Detroit congressman John Conyers. In 1988 Roxanne Brown noted: "Thirty-two years after she attracted international attention for sparking the Montgomery Bus Boycott, Mrs. Parks's ardent devotion to human rights still burns brightly, like a well-tended torch that ignites her spirit and calls her to service whenever she is needed." ... |
| 25.07.2007, 16:44 |
start [/forum/topic.php?fid=14&gotonew=1&tid=1334219]: |
189ms |
| others: | 207ms |
| total: | 448ms |
