конвертнул из dtd схему
но валидацию почемуто она не проходит на большенство элементов ругается по типу cos-nonambig: <xs:element name='vmscid'> makes the content model non-deterministic against <xs:element name='vmscid'>. Possible causes: name equality, overlapping occurrence or substitution groups. <?xml version="1.0" encoding="UTF-8" standalone="no"?> <!--W3C Schema generated by XMLSpy v2008 rel. 2 (http://www.altova.com)--> <!--Please add namespace attributes, a targetNamespace attribute and import elements according to your requirements--> <xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified"> <xs:import namespace="http://www.w3.org/XML/1998/namespace"/> <xs:element name="svc_init"> <xs:complexType> <xs:sequence> <xs:element ref="hdr"/> <xs:choice> <xs:element ref="slir"/> <xs:element ref="eme_lir"/> <xs:element ref="tlrr"/> <xs:element ref="tlrsr"/> </xs:choice> </xs:sequence> <xs:attribute name="ver" type="xs:anySimpleType" fixed="3.2.0"/> </xs:complexType> </xs:element> <xs:element name="client"> <xs:complexType> <xs:sequence> <xs:element ref="id"/> <xs:element ref="pwd" minOccurs="0"/> <xs:element ref="serviceid" minOccurs="0"/> <xs:element ref="requestmode" minOccurs="0"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="sessionid"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="id"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="requestor"> <xs:complexType> <xs:sequence> <xs:element ref="id"/> <xs:element ref="serviceid" minOccurs="0"/> </xs:sequence> <xs:attribute name="type" default="MSISDN"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="SIPURL"/> <xs:enumeration value="MSISDN"/> <xs:enumeration value="MDN"/> <xs:enumeration value="NAME"/> <xs:enumeration value="IMS"/> <xs:enumeration value="E-MAIL"/> <xs:enumeration value="URL"/> <xs:enumeration value="ASID"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="pwd"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="serviceid"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="requestmode"> <xs:complexType> <xs:attribute name="type" default="PASSIVE"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="ACTIVE"/> <xs:enumeration value="PASSIVE"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="subclient"> <xs:complexType> <xs:sequence> <xs:element ref="id"/> <xs:element ref="pwd" minOccurs="0"/> <xs:element ref="serviceid" minOccurs="0"/> </xs:sequence> <xs:attribute name="last_client" default="NO"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="YES"/> <xs:enumeration value="NO"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="msid"> <xs:complexType mixed="true"> <xs:attribute name="type" default="MSISDN"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="MSISDN"/> <xs:enumeration value="MDN"/> <xs:enumeration value="EME_MSID"/> <xs:enumeration value="SIP_URI"/> <xs:enumeration value="IMEI"/> <xs:enumeration value="MIN"/> <xs:enumeration value="TEL_URL"/> <xs:enumeration value="IMSI"/> <xs:enumeration value="IPV4"/> <xs:enumeration value="IPV6"/> <xs:enumeration value="OPE_ID"/> <xs:enumeration value="SESSID"/> <xs:enumeration value="ASID"/> </xs:restriction> </xs:simpleType> </xs:attribute> <xs:attribute name="enc" default="ASC"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="CRP"/> <xs:enumeration value="ASC"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="msid_range"> <xs:complexType> <xs:sequence> <xs:element ref="start_msid"/> <xs:element ref="stop_msid"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="msids"> <xs:complexType> <xs:sequence> <xs:choice maxOccurs="unbounded"> <xs:sequence> <xs:element ref="msid"/> <xs:element ref="codeword" minOccurs="0"/> <xs:element ref="session" minOccurs="0"/> <xs:element ref="trans_id" minOccurs="0"/> </xs:sequence> <xs:sequence> <xs:element ref="msid_range"/> <xs:element ref="codeword" minOccurs="0" maxOccurs="unbounded"/> </xs:sequence> </xs:choice> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="codeword"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="esrd"> <xs:complexType mixed="true"> <xs:attribute name="type" default="NA"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="NA"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="esrk"> <xs:complexType mixed="true"> <xs:attribute name="type" default="NA"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="NA"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="session"> <xs:complexType mixed="true"> <xs:attribute name="type" use="required"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="APN"/> <xs:enumeration value="DIAL"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="start_msid"> <xs:complexType> <xs:sequence> <xs:element ref="msid"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="stop_msid"> <xs:complexType> <xs:sequence> <xs:element ref="msid"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="trans_id"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="eme_event"> <xs:complexType> <xs:sequence> <xs:element ref="eme_pos" maxOccurs="unbounded"/> </xs:sequence> <xs:attribute name="eme_trigger" use="required"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="EME_REL"/> <xs:enumeration value="EME_ORG"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="tlrr_event"> <xs:complexType> <xs:choice> <xs:element ref="ms_action"/> <xs:element ref="change_area"/> </xs:choice> </xs:complexType> </xs:element> <xs:element name="ms_action"> <xs:complexType> <xs:attribute name="type" use="required"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="MS_AVAIL"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="change_area"> <xs:complexType> <xs:sequence> <xs:element ref="target_area"/> <xs:element ref="no_of_reports" minOccurs="0"/> </xs:sequence> <xs:attribute name="type" use="required"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="MS_WITHIN_AREA"/> <xs:enumeration value="MS_ENTERING"/> <xs:enumeration value="MS_LEAVING"/> </xs:restriction> </xs:simpleType> </xs:attribute> <xs:attribute name="loc_estimates" use="required"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="FALSE"/> <xs:enumeration value="TRUE"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="target_area"> <xs:complexType> <xs:choice> <xs:element ref="shape"/> <xs:element ref="cc"/> <xs:element ref="plmn"/> <xs:element ref="name_area"/> </xs:choice> </xs:complexType> </xs:element> <xs:element name="no_of_reports"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="name_area"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="plmn"> <xs:complexType> <xs:sequence> <xs:element ref="mcc"/> <xs:element ref="mnc"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="interval"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="loc_type"> <xs:complexType> <xs:attribute name="type" default="CURRENT"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="CURRENT"/> <xs:enumeration value="INITIAL"/> <xs:enumeration value="LAST_OR_CURRENT"/> <xs:enumeration value="LAST"/> <xs:enumeration value="CURRENT_OR_LAST"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="prio"> <xs:complexType> <xs:attribute name="type" default="NORMAL"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="HIGH"/> <xs:enumeration value="NORMAL"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="pushaddr"> <xs:complexType> <xs:sequence> <xs:element ref="url"/> <xs:element ref="id" minOccurs="0"/> <xs:element ref="pwd" minOccurs="0"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="req_id"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="start_time"> <xs:complexType mixed="true"> <xs:attribute name="utc_off" type="xs:anySimpleType" default="0000"/> </xs:complexType> </xs:element> <xs:element name="stop_time"> <xs:complexType mixed="true"> <xs:attribute name="utc_off" type="xs:anySimpleType" default="0000"/> </xs:complexType> </xs:element> <xs:element name="duration"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="url"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="time_remaining"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="lcs_ref"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="eqop"> <xs:complexType> <xs:sequence> <xs:element ref="resp_req" minOccurs="0"/> <xs:element ref="resp_timer" minOccurs="0"/> <xs:choice minOccurs="0"> <xs:element ref="ll_acc"/> <xs:element ref="hor_acc"/> </xs:choice> <xs:element ref="alt_acc" minOccurs="0"/> <xs:element ref="max_loc_age" minOccurs="0"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="qop"> <xs:complexType> <xs:sequence> <xs:choice minOccurs="0"> <xs:element ref="ll_acc"/> <xs:element ref="hor_acc"/> </xs:choice> <xs:element ref="alt_acc" minOccurs="0"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="ll_acc"> <xs:complexType mixed="true"> <xs:attribute name="qos_class"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="BEST_EFFORT"/> <xs:enumeration value="ASSURED"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="hor_acc"> <xs:complexType mixed="true"> <xs:attribute name="qos_class"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="BEST_EFFORT"/> <xs:enumeration value="ASSURED"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="alt_acc"> <xs:complexType mixed="true"> <xs:attribute name="qos_class"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="BEST_EFFORT"/> <xs:enumeration value="ASSURED"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="max_loc_age"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="resp_req"> <xs:complexType> <xs:attribute name="type" default="DELAY_TOL"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="LOW_DELAY"/> <xs:enumeration value="DELAY_TOL"/> <xs:enumeration value="NO_DELAY"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="resp_timer"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="pos"> <xs:complexType> <xs:sequence> <xs:element ref="msid"/> <xs:choice> <xs:element ref="pd"/> <xs:element ref="poserr"/> </xs:choice> <xs:element ref="gsm_net_param" minOccurs="0"/> <xs:element ref="trans_id" minOccurs="0"/> </xs:sequence> <xs:attribute name="pos_method"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="AFLT"/> <xs:enumeration value="E-OTD"/> <xs:enumeration value="UNKNOWN"/> <xs:enumeration value="CELL"/> <xs:enumeration value="GPS"/> <xs:enumeration value="U-TDOA"/> <xs:enumeration value="OTDOA"/> <xs:enumeration value="EFLT"/> <xs:enumeration value="A-GPS"/> <xs:enumeration value="OTHER"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="eme_pos"> <xs:complexType> <xs:sequence> <xs:element ref="msid"/> <xs:choice> <xs:element ref="pd"/> <xs:element ref="poserr"/> </xs:choice> <xs:element ref="esrd" minOccurs="0"/> <xs:element ref="esrk" minOccurs="0"/> <xs:element ref="trans_id" minOccurs="0"/> </xs:sequence> <xs:attribute name="pos_method"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="AFLT"/> <xs:enumeration value="E-OTD"/> <xs:enumeration value="UNKNOWN"/> <xs:enumeration value="CELL"/> <xs:enumeration value="GPS"/> <xs:enumeration value="U-TDOA"/> <xs:enumeration value="OTDOA"/> <xs:enumeration value="EFLT"/> <xs:enumeration value="A-GPS"/> <xs:enumeration value="OTHER"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="trl_pos"> <xs:complexType> <xs:sequence> <xs:element ref="msid"/> <xs:choice> <xs:element ref="pd"/> <xs:element ref="poserr"/> <xs:element ref="time"/> </xs:choice> </xs:sequence> <xs:attribute name="trl_trigger" use="required"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="MS_AVAIL"/> <xs:enumeration value="CHANGE_AREA"/> <xs:enumeration value="PERIODIC"/> </xs:restriction> </xs:simpleType> </xs:attribute> <xs:attribute name="pos_method"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="AFLT"/> <xs:enumeration value="E-OTD"/> <xs:enumeration value="UNKNOWN"/> <xs:enumeration value="CELL"/> <xs:enumeration value="GPS"/> <xs:enumeration value="U-TDOA"/> <xs:enumeration value="OTDOA"/> <xs:enumeration value="EFLT"/> <xs:enumeration value="A-GPS"/> <xs:enumeration value="OTHER"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="pd"> <xs:complexType> <xs:sequence> <xs:element ref="time"/> <xs:element ref="shape"/> <xs:sequence minOccurs="0"> <xs:element ref="alt"/> <xs:element ref="alt_unc" minOccurs="0"/> </xs:sequence> <xs:element ref="speed" minOccurs="0"/> <xs:element ref="direction" minOccurs="0"/> <xs:element ref="lev_conf" minOccurs="0"/> <xs:element ref="qos_not_met" minOccurs="0"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="poserr"> <xs:complexType> <xs:sequence> <xs:element ref="result"/> <xs:element ref="add_info" minOccurs="0"/> <xs:element ref="time"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="time"> <xs:complexType mixed="true"> <xs:attribute name="utc_off" type="xs:anySimpleType" default="0000"/> </xs:complexType> </xs:element> <xs:element name="alt"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="alt_unc"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="qos_not_met"> <xs:complexType/> </xs:element> <xs:element name="direction"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="speed"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="lev_conf"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="geo_info"> <xs:complexType> <xs:sequence> <xs:element ref="CoordinateReferenceSystem"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="CoordinateReferenceSystem"> <xs:complexType> <xs:sequence> <xs:element ref="Identifier"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="Identifier"> <xs:complexType> <xs:sequence> <xs:element ref="code"/> <xs:element ref="codeSpace"/> <xs:element ref="edition"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="code"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="codeSpace"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="edition"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="service_coverage"> <xs:complexType> <xs:sequence> <xs:sequence maxOccurs="unbounded"> <xs:element ref="cc"/> <xs:element ref="ndc" minOccurs="0" maxOccurs="unbounded"/> </xs:sequence> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="add_info"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="result"> <xs:complexType mixed="true"> <xs:attribute name="resid" type="xs:anySimpleType" use="required"/> </xs:complexType> </xs:element> <xs:element name="shape"> <xs:complexType> <xs:choice> <xs:element ref="Point"/> <xs:element ref="LineString"/> <xs:element ref="Polygon"/> <xs:element ref="Box"/> <xs:element ref="CircularArea"/> <xs:element ref="CircularArcArea"/> <xs:element ref="EllipticalArea"/> <xs:element ref="MultiLineString"/> <xs:element ref="MultiPoint"/> <xs:element ref="MultiPolygon"/> <xs:element ref="LinearRing"/> </xs:choice> </xs:complexType> </xs:element> <xs:element name="distanceUnit"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="angularUnit"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="angle"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="coord"> <xs:complexType> <xs:sequence> <xs:element ref="X"/> <xs:element ref="Y" minOccurs="0"/> <xs:element ref="Z" minOccurs="0"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="X"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="Y"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="Z"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="Point"> <xs:complexType> <xs:sequence> <xs:element ref="coord"/> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="LineString"> <xs:complexType> <xs:sequence> <xs:element ref="coord" minOccurs="2" maxOccurs="2"/> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="Box"> <xs:complexType> <xs:sequence> <xs:element ref="coord" minOccurs="2" maxOccurs="2"/> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="LinearRing"> <xs:complexType> <xs:sequence> <xs:element ref="coord" minOccurs="2" maxOccurs="2"/> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="Polygon"> <xs:complexType> <xs:sequence> <xs:element ref="outerBoundaryIs"/> <xs:element ref="innerBoundaryIs" minOccurs="0" maxOccurs="unbounded"/> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="outerBoundaryIs"> <xs:complexType> <xs:sequence> <xs:element ref="LinearRing"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="innerBoundaryIs"> <xs:complexType> <xs:sequence> <xs:element ref="LinearRing"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="CircularArcArea"> <xs:complexType> <xs:sequence> <xs:element ref="coord"/> <xs:element ref="inRadius"/> <xs:element ref="outRadius"/> <xs:element ref="startAngle"/> <xs:element ref="stopAngle"/> <xs:element ref="angularUnit" minOccurs="0"/> <xs:element ref="distanceUnit" minOccurs="0"/> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="CircularArea"> <xs:complexType> <xs:sequence> <xs:element ref="coord"/> <xs:element ref="radius"/> <xs:element ref="distanceUnit" minOccurs="0"/> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="EllipticalArea"> <xs:complexType> <xs:sequence> <xs:element ref="coord"/> <xs:element ref="angle"/> <xs:element ref="semiMajor"/> <xs:element ref="semiMinor"/> <xs:element ref="angularUnit" minOccurs="0"/> <xs:element ref="distanceUnit" minOccurs="0"/> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="inRadius"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="outRadius"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="radius"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="semiMajor"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="semiMinor"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="startAngle"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="stopAngle"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="MultiLineString"> <xs:complexType> <xs:sequence> <xs:element ref="LineString" maxOccurs="unbounded"/> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="MultiPoint"> <xs:complexType> <xs:sequence> <xs:element ref="Point" maxOccurs="unbounded"/> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="MultiPolygon"> <xs:complexType> <xs:sequence> <xs:choice maxOccurs="unbounded"> <xs:element ref="Polygon"/> <xs:element ref="Box"/> <xs:element ref="CircularArea"/> <xs:element ref="CircularArcArea"/> <xs:element ref="EllipticalArea"/> </xs:choice> </xs:sequence> <xs:attribute name="gid" type="xs:ID"/> <xs:attribute name="srsName" type="xs:anySimpleType"/> </xs:complexType> </xs:element> <xs:element name="gsm_net_param"> <xs:complexType> <xs:sequence> <xs:element ref="cgi" minOccurs="0"/> <xs:element ref="neid" minOccurs="0"/> <xs:element ref="nmr" minOccurs="0"/> <xs:element ref="ta" minOccurs="0"/> <xs:element ref="lmsi" minOccurs="0"/> <xs:element ref="imsi" minOccurs="0"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="cgi"> <xs:complexType> <xs:sequence> <xs:element ref="mcc"/> <xs:element ref="mnc"/> <xs:element ref="lac"/> <xs:element ref="cellid"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="neid"> <xs:complexType> <xs:choice> <xs:element ref="vmscid"/> <xs:element ref="vlrid"/> <xs:sequence> <xs:element ref="vmscid"/> <xs:element ref="vlrid"/> </xs:sequence> </xs:choice> </xs:complexType> </xs:element> <xs:element name="vmscid"> <xs:complexType> <xs:sequence> <xs:element ref="cc" minOccurs="0"/> <xs:element ref="ndc" minOccurs="0"/> <xs:element ref="vmscno"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="vlrid"> <xs:complexType> <xs:sequence> <xs:element ref="cc" minOccurs="0"/> <xs:element ref="ndc" minOccurs="0"/> <xs:element ref="vlrno"/> </xs:sequence> </xs:complexType> </xs:element> <xs:element name="nmr"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="mcc"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="mnc"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="ndc"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="cc"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="vmscno"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="vlrno"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="lac"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="cellid"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="ta"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="lmsi"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="imsi"> <xs:complexType mixed="true"/> </xs:element> <xs:element name="hdr"> <xs:complexType> <xs:sequence> <xs:choice> <xs:element ref="client"/> <xs:element ref="sessionid"/> <xs:sequence> <xs:element ref="client"/> <xs:element ref="sessionid"/> </xs:sequence> </xs:choice> <xs:element ref="subclient" minOccurs="0" maxOccurs="unbounded"/> <xs:element ref="requestor" minOccurs="0"/> </xs:sequence> <xs:attribute name="ver" type="xs:anySimpleType" fixed="3.2.0"/> </xs:complexType> </xs:element> <xs:element name="slir"> <xs:complexType> <xs:sequence> <xs:choice> <xs:element ref="msids"/> <xs:sequence maxOccurs="unbounded"> <xs:element ref="msid"/> <xs:element ref="codeword" minOccurs="0"/> <xs:element ref="gsm_net_param"/> <xs:element ref="trans_id" minOccurs="0"/> </xs:sequence> </xs:choice> <xs:element ref="eqop" minOccurs="0"/> <xs:element ref="geo_info" minOccurs="0"/> <xs:element ref="loc_type" minOccurs="0"/> <xs:element ref="prio" minOccurs="0"/> <xs:element ref="pushaddr" minOccurs="0"/> <xs:element ref="service_coverage" minOccurs="0"/> </xs:sequence> <xs:attribute name="ver" type="xs:anySimpleType" fixed="3.2.0"/> <xs:attribute name="res_type" default="SYNC"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="ASYNC"/> <xs:enumeration value="SYNC"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="eme_lir"> <xs:complexType> <xs:sequence> <xs:choice> <xs:element ref="msids"/> <xs:sequence maxOccurs="unbounded"> <xs:element ref="msid"/> <xs:element ref="gsm_net_param"/> <xs:element ref="trans_id" minOccurs="0"/> <xs:element ref="esrd" minOccurs="0"/> <xs:element ref="esrk" minOccurs="0"/> </xs:sequence> </xs:choice> <xs:element ref="eqop" minOccurs="0"/> <xs:element ref="geo_info" minOccurs="0"/> <xs:element ref="loc_type" minOccurs="0"/> <xs:element ref="pushaddr" minOccurs="0"/> </xs:sequence> <xs:attribute name="ver" type="xs:anySimpleType" fixed="3.2.0"/> <xs:attribute name="res_type" default="SYNC"> <xs:simpleType> <xs:restriction base="xs:NMTOKEN"> <xs:enumeration value="ASYNC"/> <xs:enumeration value="SYNC"/> </xs:restriction> </xs:simpleType> </xs:attribute> </xs:complexType> </xs:element> <xs:element name="tlrr"> <xs:complexType> <xs:sequence> <xs:element ref="msids"/> <xs:element ref="interval" minOccurs="0"/> <xs:element ref="start_time" minOccurs="0"/> <xs:element ref="stop_time" minOccurs="0"/> <xs:element ref="duration" minOccurs="0"/> <xs:element ref="tlrr_event" minOccurs="0"/> <xs:element ref="qop" minOccurs="0"/> <xs:element ref="geo_info" minOccurs="0"/> <xs:element ref="pushaddr" minOccurs="0"/> <xs:element ref="loc_type" minOccurs="0"/> <xs:element ref="prio" minOccurs="0"/> <xs:element ref="service_coverage" minOccurs="0"/> </xs:sequence> <xs:attribute name="ver" type="xs:anySimpleType" fixed="3.2.0"/> </xs:complexType> </xs:element> <xs:element name="tlrsr"> <xs:complexType> <xs:sequence> <xs:element ref="req_id"/> <xs:element ref="lcs_ref" minOccurs="0"/> </xs:sequence> <xs:attribute name="ver" type="xs:anySimpleType" fixed="3.2.0"/> </xs:complexType> </xs:element> </xs:schema> ... |
| 18.09.2008, 12:48 |
start [/forum/topic.php?fid=14&gotonew=1&tid=1333779]: |
66ms |
47ms |
| others: | 278ms |
| total: | 449ms |
