не получается задать уникальность
помогите найти ошибку пытаюс сделать уникальным поле id в итоге ставлю в хml 2 одинаковых айдишника и это валидируется без ошибок(( почему? XSD <?xml version="1.0" encoding="UTF-8"?> <schema xmlns=" http://www.w3.org/2001/XMLSchema" targetNamespace=" http://www.example.com/" xmlns:tns=" http://www.example.com/"> <element name="trains"> <complexType> <sequence> <element name="train" type="tns:Train" minOccurs="1" maxOccurs="unbounded" /> </sequence> </complexType> <unique name="uniqueId"> <selector xpath="trains/Train"/> <field xpath="@id"/> </unique> </element> <complexType name="Train"> <sequence> <element name="traintype" type="tns:TrainType" /> </sequence> <attribute name="id" type="integer" use="required" /> <attribute name="propulsion" type="tns:Propulsion" use="required" /> </complexType> <complexType name="TrainType"> <sequence> <element name="countpassengers" type="tns:CountPassengers" /> <element name="routname" type="tns:Routs" /> </sequence> </complexType> <simpleType name="Routs"> <restriction base="string"> <enumeration value="Brest-Minsk"/> <enumeration value="Minsk-Moscow"/> <enumeration value="Moscow-Piter"/> </restriction> </simpleType> <simpleType name="CountPassengers"> <restriction base="integer"> <minInclusive value="50"/> <maxInclusive value="500"/> </restriction> </simpleType> <simpleType name="Propulsion"> <restriction base="string"> <enumeration value="Diesel"/> <enumeration value="Electric"/> <enumeration value="SteamLocomotive"/> </restriction> </simpleType> </schema> xml <?xml version="1.0" encoding="UTF-8"?> <tns:trains xmlns:tns=" http://www.example.com/" xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation=" http://www.example.com/ CommuterTrain.xsd "> <train id="1" propulsion="Diesel"> <traintype> <countpassengers>100</countpassengers> <routname>Brest-Minsk</routname> </traintype> </train> <train id="1" propulsion="Electric"> <traintype> <countpassengers>100</countpassengers> <routname>Brest-Minsk</routname> </traintype> </train> </tns:trains> ... |
| 25.11.2010, 04:17 |
Код: plaintext 1. 2. 3. ... |
| 25.11.2010, 08:04 |
start [/forum/topic.php?fid=14&gotonew=1&tid=1333073]: |
90ms |
41ms |
| others: | 244ms |
| total: | 429ms |
