powered by simpleCommunicator - 2.0.56     © 2025 Programmizd 02
Форумы / XML, XSL, XPath, XQuery [игнор отключен] [закрыт для гостей] / Создать валидный XSL
    #39916224
XaKoN
Имеется XML следующей структуры:
Код: xml
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
100.
101.
102.
103.
104.
105.
106.
107.
108.
109.
110.
111.
112.
113.
114.
115.
116.
117.
118.
119.
120.
121.
122.
123.
124.
125.
126.
127.
128.
129.
130.
131.
132.
133.
134.
135.
136.
137.
138.
139.
140.
141.
142.
143.
144.
145.
146.
147.
<rsp code="ok">
<start>0
</start>
<limit>1
</limit>
<totalcount>491571
</totalcount>
<items>
<RemedyEntry>
    <populationLevel>NORMAL</populationLevel>
    <customerId>P000000615</customerId>
    <data>
        <key>ISS Ticket ID</key>
        <value>SOCJ00700902147</value>
    </data>
    <data>
        <key>LastWorkLog Entry</key>
        <value>test
This ticket has been acknowledged by the SOC</value>
    </data>
    <data>
        <key>LastWorkLog UpdatedBy</key>
        <value>AR_ESCALATOR</value>
    </data>
    <data>
        <key>LastWorkLog UpdateType</key>
        <value>MSS</value>
    </data>
    <data>
        <key>LastWorklogUpdate-DateTime</key>
        <value>Sat Sep 21 14:45:51 GMT 2019</value>
    </data>
    <data>
        <key>Private Work Log</key>
        <value>This ticket has been linked to RCA# IDGAA5V0FDGR4APP2IYZPO4ZC1GS3O by user brian.murray===
Acknowledgement was done in  162495 minute(s)
( -161055 minute(s) left)
Justification: test ticket
 asdf asd asdf asd fasdf asdfasdf asdf asdfasdf as
test
assigned to queue -- Demo Inbound
Issue Submitted as SR - Policy Tuning
(Re)Assigned to wodrich
test
***********************************************</value>
    </data>
    <data>
        <key>Public Work Log</key>
        <value>test
This ticket has been acknowledged by the SOC===
test</value>
    </data>
    <data>
        <key>Modified Date</key>
        <value>Thu Sep 26 12:21:59 GMT 2019</value>
    </data>
    <data>
        <key>LastPrivateWorklogUpdate-DateTime</key>
    </data>
    <data>
        <key>id</key>
    </data>
    <data>
        <key>customerId</key>
        <value>P000000615</value>
    </data>
    <data>
        <key>partnerId</key>
        <value>CIDD706860</value>
    </data>
    <id>SOCJ00700902147</id>
    <schema>OPS:Trouble Ticket</schema>
    <worklogData>
        <worklog>
            <entries>
                <text>This ticket has been linked to RCA# IDGAA5V0FDGR4APP2IYZPO4ZC1GS3O by user brian.murray</text>
                <timestamp>2019-05-08T17:32:22Z</timestamp>
                <type>MSS</type>
                <username>brian.murray</username>
            </entries>
            <entries>
                <text>Acknowledgement was done in  162495 minute(s)
test
***********************************************</text>
                <timestamp>2012-07-07T13:08:50Z</timestamp>
                <type>MSS</type>
                <username>kproctor</username>
            </entries>
            <entries>
                <text>assigned to queue -- Demo Inbound
test
                <timestamp>2012-03-16T16:53:55Z</timestamp>
                <type>MSS</type>
                <username>wodrich</username>
            </entries>
        </worklog>
    </worklogData>
    <worklogData>
        <worklog>
            <entries>
                <text>test
This ticket has been acknowledged by the SOC</text>
                <type>MSS</type>
            </entries>
            <entries>
                <text>test</text>
                <type>MSS</type>
            </entries>
        </worklog>
    </worklogData>
</RemedyEntry>
</items>
</rsp>
Пытался создать валидный XSL. В браузере работает, но в DataStage нет.
Суть в том, что мне нужно достать из XML поля id, key и как текст всё начиная с тегов <worklog> </worklog> для Private Work Log и Public Work Log. Уже вижу в принципе ошибку, но что посоветуете вы, я думаю она не единственная.
Код: xml
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
  <xsl:template match="/">
    <xsl:for-each select="rsp/items/RemedyEntry">
      <row>
		<column name="id">    <xsl:for-each select="data"><xsl:if test="key = 'id'"><xsl:value-of select="value"/></xsl:if></xsl:for-each></column>
		<column name="key">    <xsl:for-each select="worklogData"><xsl:value-of select="key"/></xsl:for-each></column>
		<column name="TXT">    <xsl:for-each select="worklogData/worklog/entries">
<xsl:value-of select="text"/><xsl:value-of select="timestamp"/><xsl:value-of select="type"/><xsl:value-of select="username"/>
 </row>
    </xsl:for-each>
  </xsl:template>
</xsl:stylesheet>
Потом это всё заливается в базу в виде CLOB.
