Ошибка сборки приложения
Здравствуйе! В какой-то момент перестало собираться приложение, не могу понять в какой. При сборке выдает ошибку: ошибкаInformation:Gradle tasks [:app:assembleDebug] :app:preBuild UP-TO-DATE :app:preDebugBuild UP-TO-DATE :app:checkDebugManifest :app:preReleaseBuild UP-TO-DATE :simple-fb:preBuild UP-TO-DATE :simple-fb:preReleaseBuild UP-TO-DATE :simple-fb:compileReleaseNdk UP-TO-DATE :simple-fb:compileLint :simple-fb:copyReleaseLint UP-TO-DATE :simple-fb:checkReleaseManifest :simple-fb:preDebugAndroidTestBuild UP-TO-DATE :simple-fb:preDebugBuild UP-TO-DATE :simple-fb:preDebugUnitTestBuild UP-TO-DATE :simple-fb:preReleaseUnitTestBuild UP-TO-DATE :simple-fb:prepareComAndroidSupportSupportV42221Library UP-TO-DATE :simple-fb:prepareComFacebookAndroidFacebookAndroidSdk470Library UP-TO-DATE :simple-fb:prepareReleaseDependencies :simple-fb:compileReleaseAidl UP-TO-DATE :simple-fb:compileReleaseRenderscript UP-TO-DATE :simple-fb:generateReleaseBuildConfig UP-TO-DATE :simple-fb:generateReleaseAssets UP-TO-DATE :simple-fb:mergeReleaseAssets UP-TO-DATE :simple-fb:generateReleaseResValues UP-TO-DATE :simple-fb:generateReleaseResources UP-TO-DATE :simple-fb:mergeReleaseResources UP-TO-DATE :simple-fb:processReleaseManifest UP-TO-DATE :simple-fb:processReleaseResources UP-TO-DATE :simple-fb:generateReleaseSources UP-TO-DATE :simple-fb:compileReleaseJavaWithJavac UP-TO-DATE :simple-fb:extractReleaseAnnotations UP-TO-DATE :simple-fb:mergeReleaseProguardFiles UP-TO-DATE :simple-fb:packageReleaseRenderscript UP-TO-DATE :simple-fb:packageReleaseResources UP-TO-DATE :simple-fb:processReleaseJavaRes UP-TO-DATE :simple-fb:transformResourcesWithMergeJavaResForRelease UP-TO-DATE :simple-fb:transformClassesAndResourcesWithSyncLibJarsForRelease UP-TO-DATE :simple-fb:mergeReleaseJniLibFolders UP-TO-DATE :simple-fb:transformNative_libsWithMergeJniLibsForRelease UP-TO-DATE :simple-fb:transformNative_libsWithSyncJniLibsForRelease UP-TO-DATE :simple-fb:bundleRelease UP-TO-DATE :app:prepareComAndroidSupportAppcompatV72300Library UP-TO-DATE :app:prepareComAndroidSupportSupportV42300Library UP-TO-DATE :app:prepareComFacebookAndroidFacebookAndroidSdk470Library UP-TO-DATE :app:prepareComGoogleAndroidGmsPlayServicesBase830Library UP-TO-DATE :app:prepareComGoogleAndroidGmsPlayServicesBasement830Library UP-TO-DATE :app:prepareComGoogleAndroidGmsPlayServicesGcm830Library UP-TO-DATE :app:prepareComGoogleAndroidGmsPlayServicesMeasurement830Library UP-TO-DATE :app:prepareComSromkuSimpleFb411Library UP-TO-DATE :app:prepareDebugDependencies :app:compileDebugAidl UP-TO-DATE :app:compileDebugRenderscript UP-TO-DATE :app:generateDebugBuildConfig UP-TO-DATE :app:generateDebugAssets UP-TO-DATE :app:mergeDebugAssets UP-TO-DATE :app:generateDebugResValues UP-TO-DATE :app:processDebugGoogleServices No matching client found for package name 'temp.project' :app:generateDebugResources :app:mergeDebugResources UP-TO-DATE :app:processDebugManifest UP-TO-DATE :app:processDebugResources UP-TO-DATE :app:generateDebugSources UP-TO-DATE :app:compileDebugJavaWithJavac :app:compileDebugNdk UP-TO-DATE :app:compileDebugSources :app:transformClassesWithDexForDebug UNEXPECTED TOP-LEVEL EXCEPTION: Error:Execution failed for task ':app:transformClassesWithDexForDebug'. > com.android.build.transform.api.TransformException: com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/usr/lib/jvm/java-racle/bin/java'' finished with non-zero exit value 2 Вот файл gradle Код: groovy 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. В гугле нашел, что причина может быть при импорте нескольких библиотек google play services, но у меня всего одна библиотека подключается ... |
| 29.11.2015, 22:59:10 |
Джибс http://stackoverflow.com/questions/29756188/java-finished-with-non-zero-exit-value-2-android-gradle уже проделал эти процедуры, не помогло, но сейчас уже нашел другой выход ... |
| 01.12.2015, 16:52:23 |
start [/forum/topic.php?fid=13&gotonew=1&tid=1331028]: |
169ms |
38ms |
| others: | 199ms |
| total: | 448ms |
