Gradle как собрать приложение через командную строку
При попытке собрать приложение через командную строку получаю ошибку C:\Users\KazakovNK>D:\OurPrograms\testGit\gradlew assembleDebug FAILURE: Build failed with an exception. * What went wrong: Could not determine java version from '9.0.4'. * Try: Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. * Get more help at https://help.gradle.org Android Studio 3.0.1 Gradle 4.1 ... |
| 09.04.2018, 16:37:38 |
start [/forum/topic.php?fid=13&gotonew=1&tid=1330894]: |
174ms |
| others: | 216ms |
| total: | 447ms |
