TEST
{src} create procedure sp_addlogin @loginame sysname ,@passwd sysname = Null ,@defdb sysname = 'master' -- UNDONE: DEFAULT CONFIGURABLE??? ,@deflanguage sysname = Null ,@sid varbinary(16) = Null ,@encryptopt varchar(20) = Null AS -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- set nocount on Declare @ret int -- return value of sp call -- CHECK PERMISSIONS -- IF (not is_srvrolemember('securityadmin') = 1) begin dbcc auditevent (104, 1, 0, @loginame, NULL, NULL, @sid) raiserror(15247,-1,-1) return (1) end ELSE begin dbcc auditevent (104, 1, 1, @loginame, NULL, NULL, @sid) end -- DISALLOW USER TRANSACTION -- set implicit_transactions off IF (@@trancount > 0) begin raiserror(15002,-1,-1,'sp_addlogin') return (1) end -- VALIDATE LOGIN NAME AS: -- (1) Valid SQL Name (SQL LOGIN) -- (2) No backslash (NT users only) -- (3) Not a reserved login name execute @ret = sp_validname @loginame if (@ret <> 0) return (1) if (charindex('\', @loginame) > 0) begin raiserror(15006,-1,-1,@loginame) return (1) end --Note: different case sa is allowed. if (@loginame = 'sa' or lower(@loginame) in ('public')) begin raiserror(15405, -1 ,-1, @loginame) return (1) end -- LOGIN NAME MUST NOT ALREADY EXIST -- if exists(select * from master.dbo.syslogins where loginname = @loginame) begin raiserror(15025,-1,-1,@loginame) return (1) end -- VALIDATE DEFAULT DATABASE -- IF db_id(@defdb) IS NULL begin raiserror(15010,-1,-1,@defdb) return (1) end -- VALIDATE DEFAULT LANGUAGE -- IF (@deflanguage IS NOT Null) begin Execute @ret = sp_validlang @deflanguage IF (@ret <> 0) return (1) end ELSE begin select @deflanguage = name from master.dbo.syslanguages where langid = @@default_langid --server default language if @deflanguage is null select @deflanguage = N'us_english' end -- VALIDATE SID IF GIVEN -- if ((@sid IS NOT Null) and (datalength(@sid) <> 16)) begin raiserror(15419,-1,-1) return (1) end else if @sid is null select @sid = newid() if (suser_sname(@sid) IS NOT Null) begin raiserror(15433,-1,-1) return (1) end -- VALIDATE AND USE ENCRYPTION OPTION -- declare @xstatus smallint select @xstatus = 2 -- access if @encryptopt is null select @passwd = pwdencrypt(@passwd) else if @encryptopt = 'skip_encryption_old' begin select @xstatus = @xstatus | 0x800, -- old-style encryption @passwd = convert(sysname, convert(varbinary(30), convert(varchar(30), @passwd))) end else if @encryptopt <> 'skip_encryption' begin raiserror(15600,-1,-1,'sp_addlogin') return 1 end -- ATTEMPT THE INSERT OF THE NEW LOGIN -- INSERT INTO master.dbo.sysxlogins VALUES (NULL, @sid, @xstatus, getdate(), getdate(), @loginame, convert(varbinary(256), @passwd), db_id(@defdb), @deflanguage) if @@error <> 0 -- this indicates we saw duplicate row return (1) -- UPDATE PROTECTION TIMESTAMP FOR MASTER DB, TO INDICATE SYSLOGINS CHANGE -- exec('use master grant all to null') -- FINALIZATION: RETURN SUCCESS/FAILURE -- raiserror(15298,-1,-1) return (0) -- sp_addlogin <CODE> {/src} ... |
| 13.06.2002, 13:47:00 |
TEST
{email=admin@sql<>.ru}Admin{/email} ... |
| 13.06.2002, 13:51:00 |
TEST
{email=admin@sql.ru}Admin{/email} ... |
| 13.06.2002, 13:52:00 |
TEST
{url=www.sql.ru/forum}Все в форум!{/url} ... |
TEST
create procedure sp_addlogin @loginame sysname ,@passwd sysname = Null ,@defdb sysname = 'master' -- UNDONE: DEFAULT CONFIGURABLE??? ,@deflanguage sysname = Null ,@sid varbinary(16) = Null ,@encryptopt varchar(20) = Null AS -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- set nocount on Declare @ret int -- return value of sp call -- CHECK PERMISSIONS -- IF (not is_srvrolemember('securityadmin') = 1) begin dbcc auditevent (104, 1, 0, @loginame, NULL, NULL, @sid) raiserror(15247,-1,-1) return (1) end ELSE begin dbcc auditevent (104, 1, 1, @loginame, NULL, NULL, @sid) end -- DISALLOW USER TRANSACTION -- set implicit_transactions off IF (@@trancount > 0) begin raiserror(15002,-1,-1,'sp_addlogin') return (1) end -- VALIDATE LOGIN NAME AS: -- (1) Valid SQL Name (SQL LOGIN) -- (2) No backslash (NT users only) -- (3) Not a reserved login name execute @ret = sp_validname @loginame if (@ret <> 0) return (1) if (charindex('\', @loginame) > 0) begin raiserror(15006,-1,-1,@loginame) return (1) end --Note: different case sa is allowed. if (@loginame = 'sa' or lower(@loginame) in ('public')) begin raiserror(15405, -1 ,-1, @loginame) return (1) end -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- 0 if exists(select * from master.dbo.syslogins where loginname = @loginame) begin raiserror(15025,-1,-1,@loginame) return (1) end -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- 1 IF db_id(@defdb) IS NULL begin raiserror(15010,-1,-1,@defdb) return (1) end -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- 2 IF (@deflanguage IS NOT Null) begin Execute @ret = sp_validlang @deflanguage IF (@ret <> 0) return (1) end ELSE begin select @deflanguage = name from master.dbo.syslanguages where langid = @@default_langid -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- 3 if @deflanguage is null select @deflanguage = N'us_english' end -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- 4 if ((@sid IS NOT Null) and (datalength(@sid) <> 16)) begin raiserror(15419,-1,-1) return (1) end else if @sid is null select @sid = newid() if (suser_sname(@sid) IS NOT Null) begin raiserror(15433,-1,-1) return (1) end -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- 5 declare @xstatus smallint select @xstatus = 2 -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- 6 if @encryptopt is null select @passwd = pwdencrypt(@passwd) else if @encryptopt = 'skip_encryption_old' begin select @xstatus = @xstatus | 0x800, -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- 7 @passwd = convert(sysname, convert(varbinary(30), convert(varchar(30), @passwd))) end else if @encryptopt <> 'skip_encryption' begin raiserror(15600,-1,-1,'sp_addlogin') return 1 end -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- 8 INSERT INTO master.dbo.sysxlogins VALUES (NULL, @sid, @xstatus, getdate(), getdate(), @loginame, convert(varbinary(256), @passwd), db_id(@defdb), @deflanguage) if @@error <> 0 -- SETUP RUNTIME OPTIONS / DECLARE VARIABLES -- 9 return (1) -- return value of sp call 0 exec('securityadmin'0) -- return value of sp call 1 raiserror(15298,-1,-1) return (0) -- return value of sp call 2 ... |
| 13.06.2002, 13:55:00 |
start [/forum/topic.php?desktop=1&fid=8&tid=9010]: |
82ms |
90ms |
| others: | 295ms |
| total: | 547ms |
