powered by simpleCommunicator - 2.0.59     © 2026 Programmizd 02
Форумы / Обсуждение нашего сайта (архив) [закрыт] [закрыт для гостей] / Ошибка на стартовой странице sql.ru
2 сообщений из 2, страница 1 из 1
    #7612765
kZ25
При заходе на sql.ru
Получаю следущую ошибку:
Код
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
Arithmetic overflow error converting expression to data type int.
The statement has been terminated.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: Arithmetic overflow error converting expression to data type int.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[SqlException (0x80131904): Arithmetic overflow error converting expression to data type int.
The statement has been terminated.]
   System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection) +1950890
   System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection) +4846875
   System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj) +194
   System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj) +2392
   System.Data.SqlClient.SqlDataReader.ConsumeMetaData() +33
   System.Data.SqlClient.SqlDataReader.get_MetaData() +83
   System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) +297
   System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async) +954
   System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, DbAsyncResult result) +162
   System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method) +32
   System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method) +141
   System.Data.SqlClient.SqlCommand.ExecuteReader() +89
   actualadv.ActualAdvEngine.GetBanner() +254
   actualadv.actualadvert.Page_Load(Object sender, EventArgs e) +139
   System.Web.UI.Control.OnLoad(EventArgs e) +99
   System.Web.UI.Control.LoadRecursive() +50
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
    #7613004
gR4mm
Int кончился, началась ultra. (c)
