Что бы это значило?
Захожу на свой любимый форум и вижу: Server Error in '/' Application. -------------------------------------------------------------------------------- SHUTDOWN is in progress. Login failed for user 'h_sql'. Only administrators may connect at this time. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Data.SqlClient.SqlException: SHUTDOWN is in progress. Login failed for user 'h_sql'. Only administrators may connect at this time. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [SqlException: SHUTDOWN is in progress. Login failed for user 'h_sql'. Only administrators may connect at this time.] System.Data.SqlClient.ConnectionPool.GetConnection(Boolean& isInTransaction) +474 System.Data.SqlClient.SqlConnectionPoolManager.GetPooledConnection(SqlConnectionString options, Boolean& isInTransaction) +372 System.Data.SqlClient.SqlConnection.Open() +386 ActualForum.Member.LoadMember(String RememberID) +174 ActualForum.Member..ctor(String id) +178 ActualForum.ActualBaseForm.CheckLogin() +111 ActualForum.ActualForum.Page_Load(Object sender, EventArgs e) +56 System.Web.UI.Control.OnLoad(EventArgs e) +67 System.Web.UI.Control.LoadRecursive() +35 System.Web.UI.Page.ProcessRequestMain() +731 -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:1.1.4322.573; ASP.NET Version:1.1.4322.573 Что бы это значило? Как с этим бороться, если это не какое то обслуживание сайта? Или я совсем туплю? ... |
| 02.09.2003, 12:32:00 |
Что бы это значило?
Ну просто, sql server перегружали. Новый форум http://www.actualforum.com/forum (превью) нормально такие ошибки обрабатывает. Alex ... |
| 02.09.2003, 12:38:00 |
Что бы это значило?
А интересно, через тот форум постить уже можно? ... |
| 02.09.2003, 12:46:00 |
start [/forum/topic.php?desktop=1&fid=8&tid=47038]: |
29ms |
71ms |
85ms |
| others: | 255ms |
| total: | 508ms |
