Ошибка... типа...
Не вштырил, но однажды мне этот форум выдал такой-вот листинг (зацените ): Server Error in '/' Application. -------------------------------------------------------------------------------- Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Data.SqlClient.SqlException: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [SqlException: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.] System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream) +643 System.Data.SqlClient.SqlCommand.ExecuteReader() +11 ActualForum.MemberInfo.Page_Load(Object sender, EventArgs e) +509 System.Web.UI.Control.OnLoad(EventArgs e) +67 System.Web.UI.Control.LoadRecursive() +29 System.Web.UI.Page.ProcessRequestMain() +724 -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:1.0.3705.288; ASP.NET Version:1.0.3705.288 ... |
| 07.04.2003, 13:36:00 |
Ошибка... типа...
Класс..... Много вроде не пил, а второй сервак уже дает ошибку (не знаю почему...) delphi.mastak.ru... Service Unavailable The server is temporarily busy. Try again later. -------------------------------------------------------------------------------- If you beleive this is incorrect contact the site administrator at admin@combats.ru. ... |
| 07.04.2003, 13:42:00 |
start [/forum/topic.php?desktop=1&fid=8&tid=27982]: |
62ms |
23ms |
74ms |
| others: | 280ms |
| total: | 504ms |
