Server Error in '/' Application.
Вот такую фигню увидел сегодня, 26.03.2003 в 13:17 при попытке зайти по адресу https://www.sql.ru/forum/actualthread.aspx?bid=16&tid=21907&pg=16 может, поможет чем-то: Server Error in '/' Application. -------------------------------------------------------------------------------- Timeout expired. The timeout period elapsed prior to obtaining a connection from the pool. This may have occurred because all pooled connections were in use and max pool size was reached. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.InvalidOperationException: Timeout expired. The timeout period elapsed prior to obtaining a connection from the pool. This may have occurred because all pooled connections were in use and max pool size was reached. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [InvalidOperationException: Timeout expired. The timeout period elapsed prior to obtaining a connection from the pool. This may have occurred because all pooled connections were in use and max pool size was reached.] System.Data.SqlClient.SqlConnection.Open() +763 ActualForum.Member.LoadMember(String RememberID) +173 ActualForum.Member..ctor(String id) +178 ActualForum.ActualBaseForm.CheckLogin() +111 ActualForum.ActualThread.Page_Load(Object sender, EventArgs e) +55 System.Web.UI.Control.OnLoad(EventArgs e) +67 System.Web.UI.Control.LoadRecursive() +29 System.Web.UI.Page.ProcessRequestMain() +724 -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:1.0.3705.288; ASP.NET Version:1.0.3705.288 ... |
| 26.03.2003, 13:51:00 |
Меня точно такая фигня не пускала с час - полтора. Примерно с 12:30 ... |
| 26.03.2003, 14:04:00 |
start [/forum/topic.php?desktop=1&fid=8&tid=26728]: |
36ms |
53ms |
| others: | 273ms |
| total: | 419ms |
