wtf?
Server Error in '/' Application. -------------------------------------------------------------------------------- Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.Data.SqlClient.SqlException: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [SqlException: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.] System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream) +643 System.Data.SqlClient.SqlCommand.ExecuteReader() +11 ActualForum.ActualTopics.Page_Load(Object sender, EventArgs e) +3237 System.Web.UI.Control.OnLoad(EventArgs e) +67 System.Web.UI.Control.LoadRecursive() +29 System.Web.UI.Page.ProcessRequestMain() +724 -------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:1.0.3705.209; ASP ... |
| 21.09.2002, 20:42:00 |
start [/forum/search_topic.php?author=%D0%B1%D0%B5%D0%BB%D0%B8%D1%81%D1%81%D0%B8%D0%BC%D0%BE+%D0%BC%D0%BE%D0%BD+%D1%81%D0%B8%D0%BD%D1%8C%D0%BE%D1%80%D0%B5&author_mode=last_posts&do_search=1]: |
26ms |
26ms |
29ms |
28ms |
28ms |
29ms |
28ms |
29ms |
26ms |
27ms |
26ms |
23ms |
28ms |
28ms |
29ms |
23ms |
26ms |
28ms |
82ms |
65ms |
| others: | 24558ms |
| total: | 25632ms |
