Ошибка синхронизации Outlook
Outlook 2003. Синхронизация с Exchange 2K. Ошибка синронизации: 17:43:00 Синхронизатор версии 11.0.5604 17:43:00 Синхронизация почтового ящика 17:43:00 Синхронизация иерархии 17:43:03 Готово 17:43:03 Автономная адресная книга Microsoft Exchange 17:43:03 0X8004010F Где собака? ... |
| 16.04.2004, 17:49 |
Темный, поздравляю с первым вопросом! ... |
| 16.04.2004, 17:50 |
Я здесь: Гав-Гав! ... |
| 16.04.2004, 18:00 |
типа первый ответ ;) ничего что на английском? если что, переведу ))) Hi, I have been struggling with this stupid problem myself. Also searched on Google and found out it has something to do with the Offline address book. Try out yourself, open Outlook (work offline) and open the address book. It will be probably empty. No go back online and on the menu click TOOLS > SEND/RECEIVE > DOWNLOAD ADDRESS BOOK. It will probably produce the same error. I managed to solve this like this (I am running Exchange 2K3 and Outlook 2K3 by the way). On your mailserver, open Exchange System Manager and on the left click on RECEPIENTS > OFFLINE ADDRESS LISTS. Normally on the right you will see a default offline address list. Now rightclick on this and click on REBUILD. It will prompt you it can take a while on lare distribution lists but go ahead. When this is done, go back to an Outlook client and try to download the offline address book. Normally it will succeed. No hit F9 and the send/receive will produce no errors anymore. Надеюсь, что помогло ) ... |
| 16.04.2004, 18:01 |
Ещё вот что можно попробовать - Offline files are disabled by doing the following: 1) In Outlook, click on the Tools menu. 2) Click Email Accounts. 3) Select "View or change existing email accounts" and click Next. 4) Select the Microsoft Exchange Server process and click on the Change button. 5) In the Exchange Server Settings dialog box, click the More Settings button. 6) Click on the Advanced tab. 7) Remove the check in the box next to Use Cached Exchange Mode. 8) Click on the Offline Folder File Settings button. 9) Click the button labelled Disable Offline Use. 10) Click OK. 11) Restart Outlook. Let me know the results. ... |
| 16.04.2004, 18:02 |
1-й вариант не помог. 2-й вариант помогает, но из-за него возникают новые траблы: при открытиии любого сообщения, точнее при попытке открыть сообщение он (Аутлук) выдают сообщение "Сбой операции. Не хватает памяти". Из-за чего и была поставлена эта мерзкая галочка Юзать кеш. Найдено эмпирическим путем, поэтому вполне вероятно, что неверно :( ... |
| 16.04.2004, 18:07 |
может это дело решается какими-то патчами? в любом случае советую залезть в гугл, набрать там 0X8004010F outlook Microsoft Exchange там народ уже с этой проблемой навоевался... ... |
| 16.04.2004, 18:23 |
Не полезу. Пусть админ сам лезет, гад! :) ... |
| 16.04.2004, 18:36 |
Ну не могу не привести сей топик без перевода. Рыдал - это слабо сказано: Outlook 2003. Конфедерация с Exchange 2K. Коллега синронизации: 17:43:00 Звукорежиссёр талии 11.0.5604 17:43:00 Конфедерация рюкзачного службиста 17:43:00 Партконференция адаптации 17:43:03 Понуро 17:43:03 Заржавелая бессмертная роса Microsoft Exchange 17:43:03 0X8004010F Где аллейка? Темный, восхваляю с шпульным ферритом! 1-й аллопат не подверг. 2-й некромант полыхает, но из-за него прошибают грязные траблы: при открытиии любого утолщения, жаднее при тиранке сдёрнуть прегрешение он (Аутлук) устают истязание "Бай фильмокопии. Не спасает устности". Из-за чего и мстила распознана эта меткая петличка Юзать кеш. Прогнано летаргическим путем, поэтому вполне нелегально, что подвижно :( ... |
| 20.04.2004, 18:06 |
start [/forum/topic.php?desktop=1&fid=61&tid=2186814]: |
132ms |
27ms |
| others: | 210ms |
| total: | 395ms |
