SQL to EXCEL SUM Column
Привет всем! Кто в курсе как а Excel можно получить сумму открытой записи sum.rstTemp!XXX Не переберая их. Спасибо. ... |
| 10.12.2005, 22:20:59 |
oExcel.WorkBooks(1).Sheets(1).Range('A10').Formula='=SUM(A1:A9)' ... |
| 11.12.2005, 09:58:48 |
http://www.firststeps.ru/sql/r.php?7 Посмотри может поможет, ну а если получится надеюсь раскажешь. ... |
| 12.12.2005, 10:18:37 |
Sub BalanceALL() ThisWorkbook.Worksheets("Balance").Cells.Delete Dim fso, fld, f1, ts, f Dim Cnxn As ADODB.Connection Dim strCnxn As String Dim strSQLAuthors As String Dim rstTemp As ADODB.Recordset Set Cnxn = New ADODB.Connection Set rstTemp = New ADODB.Recordset Set fso = CreateObject("Scripting.FileSystemObject") Set fld = fso.GetFolder("C:\Program Files\BWMeter\Data") Set fc = fld.Files Cnxn.Open "Provider='sqloledb';Data Source='127.0.0.1';Initial Catalog='Home';Integrated Security='SSPI'" For Each f1 In fc If Right(f1.Name, 3) = "sts" Then fname = fso.GetBaseName(f1.Name) strSQLAuthors = "SELECT DateTime FROM BwMeter WHERE Filter = '" & fname & "'" rstTemp.CursorLocation = adUseClient rstTemp.Open strSQLAuthors, Cnxn, adOpenDynamic, adLockOptimistic, adCmdText rstTemp.Sort = "DateTime" If rstTemp.EOF Then rstTemp.Close: GoTo 10 rstTemp.MoveFirst Date_Time = rstTemp!DateTime rstTemp.Close Set rstTemp = Nothing Set rstTemp = New ADODB.Recordset Do DoEvents d0 = DateValue("01." & Format(Date_Time, "mm.yyyy")) d1 = DateValue(d0 - 1) d2 = DateValue("01." & Format(d0 + 31, "mm.yyyy")) d4 = d2 d3 = (DateValue(d2) - 1) + TimeValue("23:30:00") d1 = Format(d1, "mm.dd.yyyy hh:mm:ss") d2 = Format(d2, "mm.dd.yyyy hh:mm:ss") strSQLAuthors = "SELECT Sum(Íà÷èñëåííî) FROM BwMeter WHERE Filter = '" & fname & "' and DateTime> '" & d1 & "' and DateTime< '" & d2 & "'" rstTemp.Open strSQLAuthors, Cnxn, adOpenDynamic, adLockOptimistic, adCmdText If rstTemp.EOF Then rstTemp.Close: GoTo 20 SumTemp = rstTemp(0) rstTemp.Close Set rstTemp = Nothing Set rstTemp = New ADODB.Recordset If SumTemp = 0 Then GoTo 20 strSQLAuthors = "SELECT DateTime,Ñòîèìîñòü,Filter,Date_Time FROM BwMeter WHERE Filter = '" & fname & "' and Date_Time= '" & d3 & "'" rstTemp.Open strSQLAuthors, Cnxn, adOpenDynamic, adLockOptimistic, adCmdText If Not rstTemp.EOF Then rstTemp!Filter = fname rstTemp!DateTime = d3 rstTemp!Date_Time = d3 s = (SumTemp / 1024 / 1024) If s > 4000 Then rstTemp!Ñòîèìîñòü = s * 44: GoTo 21 If s > 3000 Then rstTemp!Ñòîèìîñòü = s * 46: GoTo 21 If s > 2500 Then rstTemp!Ñòîèìîñòü = s * 48: GoTo 21 If s > 2000 Then rstTemp!Ñòîèìîñòü = s * 51: GoTo 21 If s > 1500 Then rstTemp!Ñòîèìîñòü = s * 55: GoTo 21 If s > 1000 Then rstTemp!Ñòîèìîñòü = s * 58: GoTo 21 If s > 900 Then rstTemp!Ñòîèìîñòü = s * 60: GoTo 21 If s > 800 Then rstTemp!Ñòîèìîñòü = s * 65: GoTo 21 If s > 600 Then rstTemp!Ñòîèìîñòü = s * 70: GoTo 21 If s > 500 Then rstTemp!Ñòîèìîñòü = s * 75: GoTo 21 If s > 400 Then rstTemp!Ñòîèìîñòü = s * 80: GoTo 21 If s > 300 Then rstTemp!Ñòîèìîñòü = s * 85: GoTo 21 If s > 250 Then rstTemp!Ñòîèìîñòü = s * 90: GoTo 21 If s > 200 Then rstTemp!Ñòîèìîñòü = s * 95: GoTo 21 If s > 150 Then rstTemp!Ñòîèìîñòü = s * 100: GoTo 21 If s > 100 Then rstTemp!Ñòîèìîñòü = s * 110: GoTo 21 If s > 50 Then rstTemp!Ñòîèìîñòü = s * 120: GoTo 21 If s <= 50 Then rstTemp!Ñòîèìîñòü = 6500: GoTo 21 Else rstTemp.AddNew rstTemp!DateTime = d3 rstTemp!Date_Time = d3 rstTemp!Filter = fname s = (SumTemp / 1024 / 1024) If s > 4000 Then rstTemp!Ñòîèìîñòü = s * 44: GoTo 21 If s > 3000 Then rstTemp!Ñòîèìîñòü = s * 46: GoTo 21 If s > 2500 Then rstTemp!Ñòîèìîñòü = s * 48: GoTo 21 If s > 2000 Then rstTemp!Ñòîèìîñòü = s * 51: GoTo 21 If s > 1500 Then rstTemp!Ñòîèìîñòü = s * 55: GoTo 21 If s > 1000 Then rstTemp!Ñòîèìîñòü = s * 58: GoTo 21 If s > 900 Then rstTemp!Ñòîèìîñòü = s * 60: GoTo 21 If s > 800 Then rstTemp!Ñòîèìîñòü = s * 65: GoTo 21 If s > 600 Then rstTemp!Ñòîèìîñòü = s * 70: GoTo 21 If s > 500 Then rstTemp!Ñòîèìîñòü = s * 75: GoTo 21 If s > 400 Then rstTemp!Ñòîèìîñòü = s * 80: GoTo 21 If s > 300 Then rstTemp!Ñòîèìîñòü = s * 85: GoTo 21 If s > 250 Then rstTemp!Ñòîèìîñòü = s * 90: GoTo 21 If s > 200 Then rstTemp!Ñòîèìîñòü = s * 95: GoTo 21 If s > 150 Then rstTemp!Ñòîèìîñòü = s * 100: GoTo 21 If s > 100 Then rstTemp!Ñòîèìîñòü = s * 110: GoTo 21 If s > 50 Then rstTemp!Ñòîèìîñòü = s * 120: GoTo 21 If s <= 50 Then rstTemp!Ñòîèìîñòü = 6500: GoTo 21 End If 21: rstTemp.UpdateBatch rstTemp.Close 20: Date_Time = d4 If DateValue(d3) > Date Then Exit Do Loop If fname = "SQL" Or _ fname = "ADSLStop" Or _ fname = "LAN" Or _ fname = "RDP" Or _ fname = "Denis" Or _ fname = "ADSL" Or _ fname = "Jet" Or _ fname = "diary.ru " Or _ fname = "Icq" Or _ fname = "Internet" Or _ fname = "LanToInternet" Or _ fname = "Mochalo" Or _ fname = "SQLStop" Or _ fname = "diary.ru" Or _ fname = "StopAllInternet" Or _ fname = "StopInternet2" Or _ fname = "Test" Or _ fname = "StopNet" Or _ fname = "StopInternet" _ Then GoTo 10 strSQLAuthors = "SELECT Sum(Îïëà÷åíî-Ñòîèìîñòü) FROM BwMeter WHERE Filter = '" & fname & "'" rstTemp.Open strSQLAuthors, Cnxn, adOpenDynamic, adLockOptimistic, adCmdText SumTemp = rstTemp(0) rstTemp.Close a = 1 Do While ThisWorkbook.Worksheets("Balance").Cells(a, 1) <> "" a = a + 1 Loop ThisWorkbook.Worksheets("Balance").Cells(a, 1) = fname ThisWorkbook.Worksheets("Balance").Cells(a, 2) = SumTemp ThisWorkbook.Worksheets("Balance").Cells(a, 3) = Now 10: End If Next ThisWorkbook.Worksheets("Balance").Cells.Sort Key1:=ThisWorkbook.Worksheets("Balance").Cells.Range("B1"), Order1:=xlAscending, Header:=xlGuess, _ OrderCustom:=1, MatchCase:=False, Orientation:=xlTopToBottom, _ DataOption1:=xlSortNormal ThisWorkbook.Worksheets("Balance").Cells.EntireColumn.AutoFit End Sub Private Sub SaveSql1() Dim fso, fld, f1, ts, f Dim Cnxn As ADODB.Connection Dim strCnxn As String Dim strSQLAuthors As String Dim rstTemp As ADODB.Recordset Set Cnxn = New ADODB.Connection Set rstTemp = New ADODB.Recordset Set fso = CreateObject("Scripting.FileSystemObject") Set fld = fso.GetFolder("C:\Program Files\BWMeter\Data") Set fc = fld.Files Cnxn.Open "Provider='sqloledb';Data Source='127.0.0.1';Initial Catalog='Home';Integrated Security='SSPI'" For Each f1 In fc If Right(f1.Name, 3) = "sts" Then fname = fso.GetBaseName(f1.Name) strSQLAuthors = "SELECT DateTime,Íà÷èñëåííî,Ñòîèìîñòü,Îïëà÷åíî FROM BwMeter WHERE Filter = '" & fname & "' and Ñòîèìîñòü!=0" rstTemp.Open strSQLAuthors, Cnxn, adOpenDynamic, adLockOptimistic, adCmdText Do While Not rstTemp.EOF rstTemp!Ñòîèìîñòü = 0 rstTemp.UpdateBatch rstTemp.MoveNext Loop rstTemp.Close End If Next Cnxn.Close End Sub Sub BalanceClient() On Error GoTo 1 Dim Cnxn As ADODB.Connection Dim strCnxn As String Dim strSQLAuthors As String Dim rstTemp As ADODB.Recordset Set Cnxn = New ADODB.Connection Set rstTemp = New ADODB.Recordset User = "Internet" Pass = "27fd92l1I0" Cnxn.Open "Provider='sqloledb';Data Source='192.168.111.1';Initial Catalog='Home';;User ID='" & User & "';Password= '" & Pass & "';" GetUser = ActiveCell If GetUser = "" Then End If IsNumeric(GetUser) Then End If IsDate(GetUser) Then End strSQLAuthors = "SELECT DateTime,Download,Upload,Íà÷èñëåííî,Ñòîèìîñòü,Îïëà÷åíî FROM BwMeter WHERE Filter = '" & GetUser & "'" rstTemp.CursorLocation = adUseClient rstTemp.Open strSQLAuthors, Cnxn, adOpenDynamic, adLockOptimistic, adCmdText rstTemp.Sort = "DateTime" If Not rstTemp.EOF Then ThisWorkbook.Worksheets("Statistik").Cells.ClearContents ThisWorkbook.Worksheets("Statistik").Cells(1, 7) = GetUser ThisWorkbook.Worksheets("Statistik").Cells(1, 1) = "DateTime" ThisWorkbook.Worksheets("Statistik").Cells(1, 2) = "Download" ThisWorkbook.Worksheets("Statistik").Cells(1, 3) = "Upload" ThisWorkbook.Worksheets("Statistik").Cells(1, 4) = "Íà÷èñëåííî" ThisWorkbook.Worksheets("Statistik").Cells(1, 5) = "Ñòîèìîñòü" ThisWorkbook.Worksheets("Statistik").Cells(1, 6) = "Îïëà÷åíî" ThisWorkbook.Worksheets("Statistik").Cells(2, 1).CopyFromRecordset rstTemp ThisWorkbook.Worksheets("Statistik").Columns("A:A").NumberFormat = "dd/mm/yyyy hh:mm:ss" ThisWorkbook.Worksheets("Statistik").Range("H1").FormulaR1C1 = "=SUM(C[-3])" ThisWorkbook.Worksheets("Statistik").Range("I1").FormulaR1C1 = "=SUM(C[-3])" 'ThisWorkbook.Worksheets("Statistik").Cells.Sort Key1:=ThisWorkbook.Worksheets("Statistik").Range("A2"), Order1:=xlAscending, Header:= _ xlGuess, OrderCustom:=1, MatchCase:=False, Orientation:=xlTopToBottom, _ DataOption1:=xlSortNormal ThisWorkbook.Worksheets("Statistik").Range("J1").NumberFormat = "[Green]#,##0_ð_.;[Red]-#,##0_ð_." ThisWorkbook.Worksheets("Statistik").Range("J1").FormulaR1C1 = "=RC[-1]-RC[-2]" ThisWorkbook.Worksheets("Statistik").Cells.EntireColumn.AutoFit End If rstTemp.Close Worksheets("Statistik").Select 1: End Sub Sub BalanceClientAdd() Dim Cnxn As ADODB.Connection Dim strCnxn As String Dim strSQLAuthors As String Dim rstTemp As ADODB.Recordset Set Cnxn = New ADODB.Connection Set rstTemp = New ADODB.Recordset GetUser = ActiveCell g = InputBox(GetUser) If g = 0 Or g = "" Then End If GetUser = "" Then End If IsNumeric(GetUser) Then End If IsDate(GetUser) Then End Cnxn.Open "Provider='sqloledb';Data Source='127.0.0.1';Initial Catalog='Home';Integrated Security='SSPI'" strSQLAuthors = "SELECT DateTime,Filter,Date_Time,Îïëà÷åíî FROM BwMeter WHERE Filter = '" & GetUser & "'" rstTemp.Open strSQLAuthors, Cnxn, adOpenDynamic, adLockOptimistic, adCmdText s = Format(Now, "dd.mm.yyyy hh:mm:ss") rstTemp.AddNew rstTemp!DateTime = s rstTemp!Date_Time = s rstTemp!Îïëà÷åíî = g rstTemp!Filter = GetUser rstTemp.UpdateBatch End Sub ... |
| 15.01.2006, 21:52:15 |
start [/forum/topic.php?desktop=1&fid=61&tid=2185364]: |
44ms |
26ms |
| others: | 200ms |
| total: | 299ms |
