MS Project VBA
Всем привет!!! Недавно столкнулся с такой проблемой, что не мог подтянуть значения с sql базы в ms project... Я облазил кучу форумов, но ничего интересного так и не нашел... Задачу в итоге я сделал и вот решил выкинуть сюда, может кому и пригодится) Хронимка на ms sql server 2005: set ANSI_NULLS ON set QUOTED_IDENTIFIER ON go ALTER PROCEDURE [dbo].[AGRRpt_StaffTasks] AS BEGIN SET NOCOUNT ON; DECLARE @Start as datetime set @Start= GetDate() select TOP 1000 TASK.TASKID,'' as Fio,Place.PlaceName as PlaceCode, (case isnull(Part.ProductId,0) when 0 then Part.PartName else Product.ProductName end ) as PartName, Task.TaskName, Task.StartDateTime,Task.FinishDateTime,PT1.Shift as Shift1,PT2.Shift as Shift2, isnull(Part.PartVolume,'') as Kol, (case year(Task.StartDateTime) when year(@Start) then (case month(Task.StartDateTime) when month(@Start) then (case day(Task.StartDateTime) when day(@Start) then (case PT1.Shift when 1 then isnull(Part.PartVolume,0) else 0 end) else 0 end) else 0 end ) else 0 end) as Zap1, (case year(Task.FinishDateTime) when year(@Start) then (case month(Task.FinishDateTime) when month(@Start) then (case day(Task.FinishDateTime) when day(@Start) then (case PT2.Shift when 1 then isnull(Part.PartVolume,0) else 0 end) else 0 end) else 0 end ) else 0 end) as Sd1, (case year(Task.StartDateTime) when year(@Start) then (case month(Task.StartDateTime) when month(@Start) then (case day(Task.StartDateTime) when day(@Start) then (case PT1.Shift when 2 then isnull(Part.PartVolume,0) else 0 end) else 0 end) else 0 end ) else 0 end) as Zap2, (case year(Task.FinishDateTime) when year(@Start) then (case month(Task.FinishDateTime) when month(@Start) then (case day(Task.FinishDateTime) when day(@Start) then (case PT2.Shift when 2 then isnull(Part.PartVolume,0) else 0 end) else 0 end) else 0 end ) else 0 end) as Sd2, (case year(Task.StartDateTime) when year(@Start) then (case month(Task.StartDateTime) when month(@Start) then (case day(Task.StartDateTime) when day(@Start) then (case PT1.Shift when 3 then isnull(Part.PartVolume,0) else 0 end) else 0 end) else 0 end ) else 0 end) as Zap3, (case year(Task.FinishDateTime) when year(@Start) then (case month(Task.FinishDateTime) when month(@Start) then (case day(Task.FinishDateTime) when day(@Start) then (case PT2.Shift when 3 then isnull(Part.PartVolume,0) else 0 end) else 0 end) else 0 end ) else 0 end) as Sd3 from PlanTask AS Task left join PlanPart as Part on Task.PartId=Part.PartId left join PlanProduct as Product on Part.ProductId=Product.ProductId left join PlanPlace as Place on Task.PlaceId=Place.PlaceId left join PlanTime AS PT1 on Task.StartDateTime>PT1.StartDateTime and Task.StartDateTime<=PT1.FinishDateTime left join PlanTime AS PT2 on Task.FinishDateTime>PT2.StartDateTime and Task.FinishDateTime<=PT2.FinishDateTime where (Task.StateId is null or Task.StateId=30) and ((year(Task.StartDateTime)=year(GetDate()) and month(Task.StartDateTime)=month(GetDate()) and day(Task.StartDateTime)=day(GetDate())) or (year(Task.FinishDateTime)=year(GetDate()) and month(Task.FinishDateTime)=month(GetDate()) and day(Task.FinishDateTime)=day(GetDate()))) and right(Task.TaskName,4)='_032' ORDER BY Place.PlaceTechId,Task.StartDateTime,Task.FinishDateTime END Сам макрос в ms project: Sub SQLUpdate() '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' 'Создаем переменные 'SQL Dim cSQLSrv As String Dim cSQLUsr As String Dim cSQLPwd As String Dim cSQLDB As String Dim cSQLWID As String Dim cSQLApp As String Dim sSQLQry As String Dim GRRpt_StaffTasks As String 'ADODB Dim cConStr As String Dim oCon As ADODB.Connection Dim oCmd As ADODB.Command Dim oRec As ADODB.Recordset 'Project Dim iRow As String Dim oTask As Task Dim r As String '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ' Получаем данные с SQL сервера 'Подключаемся к SQL серверу cSQLSrv = "SQL сервер" cSQLUsr = "Логин" cSQLPwd = "Пароль" cSQLDB = "Ваша база" cSQLWID = Application.UserName cSQLApp = Application.Name cConStr = "Provider = SQLOLEDB;" + _ "Password = " + cSQLPwd + ";" + _ "User ID=" + cSQLUsr + ";" + _ "Initial Catalog=" + cSQLDB + ";" + _ "Data Source=...;" Set oCon = CreateObject("ADODB.Connection") oCon.ConnectionString = cConStr oCon.Open Set oCmd = CreateObject("ADODB.Command") oCmd.ActiveConnection = oCon oCmd.CommandType = adCmdText oCmd.CommandText = "dbo.AGRRpt_StaffTasks" Set oRec = oCmd.Execute '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' 'Заполняем документ iRow = 0 Do Until oRec.EOF iRow = iRow + 1 'Добавляем задачу Set oTask = ActiveProject.Tasks.Add(oRec.Fields("TaskName").Value) 'Устанавливаем сроки oTask.ResourceNames = oRec.Fields("PlaceCode").Value oTask.Text1 = oRec.Fields("PartName") oTask.Start = oRec.Fields("StartDateTime").Value oTask.Finish = oRec.Fields("FinishDateTime").Value Set oTask = Nothing oRec.MoveNext Loop '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ' Финиш Set oCmd = Nothing Set oRec = Nothing Set oCon = Nothing End Sub Заполняет строки на ура... ... |
| 25.06.2013, 11:48 |
MS Project VBA
AleKs20выкинуть сюда может кому и пригодитсячтобы это кому-то действительно пригодилось, стоило бы не "выкинуть", а придумать соответствующий заголовок темы, чтобы хоть кто-то мог ее найти, а также, как я уже просил, прочитать FAQ и правильно оформить выложенный код (с тэками SQL и VB) ... |
| 25.06.2013, 11:58 |
start [/forum/topic.php?desktop=1&fid=61&tid=2174715]: |
88ms |
47ms |
| others: | 246ms |
| total: | 435ms |
