отправка писем из Excel vba через lotus 8.5
Раньше когда была версия Lotus 7 отправлялись письма и вложения без проблем, как только сменил Лотус на 8.5 тело письма и вложения не доходят до адресата, что сделать? Вот код ниже, как его подправить под Лотус 8.5 ? ' ОТПРАВЛЯЕМ ПОЧТУ ЧЕРЕЗ ЛОТУС Dim Maildb As Object 'The mail database Dim UserName As String 'The current users notes name Dim MailDbName As String 'The current users notes mail database name Dim MailDoc As Object 'The mail document itself Dim AttachME As Object 'The attachment richtextfile object Dim Session As Object 'The notes session Dim EmbedObj As Object 'The embedded object (Attachment) Dim Subject As String 'The subject string Dim Attachment As String 'The path to the attachemnt string Dim Recipient As String 'The Recipient string (or you could use the list) Dim Recip(10) As Variant 'The Recipient list Dim BodyText As Object 'The body text Dim SaveIt As Boolean 'Save to sent mail Dim WasOpen As Integer 'Checking to see if the Mail DB was already 'open to determine if session should be 'closed (0) or left alone (1) Dim ClipBoard As DataObject 'Data object for getting text from clipboard Subject = Subject_put Recipient = email ' Тело сообщения Worksheets("Sheet2").Range("A1:A30").Copy Set ClipBoard = New DataObject ClipBoard.GetFromClipboard SaveIt = True Set Session = CreateObject("Notes.NotesSession") UserName = Session.UserName MailDbName = Left$(UserName, 1) & Right$(UserName, (Len(UserName) - InStr(1, UserName, " "))) & ".nsf" Set Maildb = Session.GETDATABASE("", MailDbName) If Maildb.IsOpen = True Then WasOpen = 1 'Already open for mail Else WasOpen = 0 Maildb.OPENMAIL 'This will prompt you for password End If Set MailDoc = Maildb.CREATEDOCUMENT MailDoc.Form = "Memo" MailDoc.sendto = Recipient 'Or use Racip(10) for multiple MailDoc.Subject = Subject MailDoc.Body = ClipBoard.GetText(1) MailDoc.SAVEMESSAGEONSEND = SaveIt Filenamesend = "C:\MY\Отходы и лом\Получение отходов\Контракты\" + Filename + "\Работа с Договором и документами\" + _ Filename + "-СМКТС от " + Format(Date, "dd-mm-yyyy") + ".pdf" fl = Dir(Filenamesend) Attachment1 = Filenamesend ' Required File Name If Attachment1 <> "" Then On Error Resume Next Set AttachME = MailDoc.CREATERICHTEXTITEM("attachment1") Set EmbedObj1 = AttachME.EMBEDOBJECT(1454, "attachment1", Filenamesend, "") 'Required File Name On Error Resume Next End If MailDoc.PostedDate = Now() 'Gets the mail to appear in the sent items folder MailDoc.SEND 0, Recipient Range("A1").Select Application.CutCopyMode = False Set Maildb = Nothing Set MailDoc = Nothing Set AttachME = Nothing Set EmbedObj = Nothing If WasOpen = 1 Then Set Session = Nothing ElseIf WasOpen = 0 Then Session.Close Set Session = Nothing End If 'MsgBox "Заказ успешно отправлен:) ", vbOKOnly ... |
| 23.10.2012, 10:45 |
Учимся использовать тэги оформления кода - FAQ ... |
| 23.10.2012, 10:53 |
Shocker.Pro, ? не нашел никакого ответа на свою проблему ... |
| 23.10.2012, 13:06 |
Кто сказал, что там есть ответ на вашу проблему. Я лишь прошу оформлять код наглядно, тогда желающих помочь с вашей проблемой будет гораздо больше Код: vbnet 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25. 26. 27. 28. 29. 30. 31. 32. 33. 34. 35. 36. 37. 38. 39. 40. 41. 42. 43. 44. 45. 46. 47. 48. 49. 50. 51. 52. 53. 54. 55. 56. 57. 58. 59. 60. 61. 62. 63. 64. 65. 66. 67. 68. 69. 70. 71. 72. 73. 74. 75. 76. 77. 78. 79. 80. 81. 82. 83. 84. ... |
| 23.10.2012, 13:27 |
Shocker.Pro, ну да спасибо за наглядность ... |
| 23.10.2012, 13:30 |
> palado, > Раньше когда была версия Lotus 7 отправлялись письма и вложения без проблем, как только сменил Лотус на 8.5 > Вот код ниже, как его подправить под Лотус 8.5 ? Открывать список изменений в объектной модели Лотус начиная с 7+ до 8.5. Искать там имена знакомых используемых в программе объектов. Внимательно читатать. Делать выводы. ... |
| 24.10.2012, 00:36 |
palado, попробуйте сперва хотя бы перед отправкой поставить Код: vbnet 1. 2. 3. а то может отправка и не происходит, а Вы убили обработку ошибок Код: vbnet 1. ... |
| 25.10.2012, 08:11 |
HandKot, вот кстати работающий пример автор Public Sub sendEmail(EMailSendTo As String, EmailSubject As String, EMailBody As String) Dim objNotesSession As Object Dim objNotesMailFile As Object Dim objNotesDocument As Object Dim objNotesField As Object Dim sendmail As Boolean Dim dbString As String On Error GoTo SendMailError Set objNotesSession = CreateObject("Notes.NotesSession") On Error Resume Next dbString = objNotesSession.GetEnvironmentString("MailFile", True) Set objNotesMailFile = objNotesSession.GETDATABASE(MailServer, dbString) 'Open Mail objNotesMailFile.OPENMAIL On Error GoTo 0 'Create New Memo Set objNotesDocument = objNotesMailFile.createdocument Dim oWorkSpace As Object, oUIdoc As Object Set oWorkSpace = CreateObject("Notes.NotesUIWorkspace") Set oUIdoc = oWorkSpace.CurrentDocument 'Create 'Subject Field' Set objNotesField = objNotesDocument.APPENDITEMVALUE("Subject", EmailSubject) 'Create 'Send To' Field Set objNotesField = objNotesDocument.APPENDITEMVALUE("SendTo", EMailSendTo) 'Create 'Blind Copy To' Field Set objNotesField = objNotesDocument.APPENDITEMVALUE("Subject", EmailSubject) 'Create 'Body' of memo Set objNotesField = objNotesDocument.CREATERICHTEXTITEM("Body") With objNotesField .APPENDTEXT EMailBody .ADDNEWLINE 1 End With 'Send the e-mail Call objNotesDocument.Save(True, False, False) objNotesDocument.SaveMessageOnSend = True 'objNotesDocument.Save objNotesDocument.Send (0) 'Release storage Set objNotesSession = Nothing Set objNotesMailFile = Nothing Set objNotesDocument = Nothing Set objNotesField = Nothing 'Set return code sendmail = True Exit Sub SendMailError: Dim Msg Msg = "Error # " & Str(Err.Number) & " was generated by " _ & Err.Source & Chr(13) & Err.Description MsgBox Msg, , "Error", Err.HelpFile, Err.HelpContext sendmail = False End Sub ... |
| 08.11.2012, 15:35 |
Chumakov_JA, вы не первый день на форуме, прошу научиться пользоваться тэгами оформления кода. ... |
| 08.11.2012, 15:37 |
Доброго дня господа ! Имею еще проблему по Lotus Как и где именно ввести пароль (на базу на сессию) Set Session = CreateObject("Notes.NotesSession") Call Session.Initialize("MyPassword") - ругаеться !!!!!!!!!!!! Но вываливаеться окно с запросмо на пароль ? ... |
| 11.03.2014, 14:38 |
start [/forum/topic.php?desktop=1&fid=61&tid=2174140]: |
60ms |
42ms |
| others: | 211ms |
| total: | 353ms |
